SOURCE: HP Color LaserJet 2840 making awful noises
This can be numerous issues really.
Either the paper being used the printer does not like, this can be the texture, type, size etc try making sure all the rollers are clean. If problem persists Id take it to get a service done.
Good luck
SOURCE: My HP Laserjet 1200 is screeching constantly
Probably the laser-mirror motor. It will screech until the load gives a error and the printer shows error/ is dead.
However, the motor can be lubed. Remove sides, remove screws found, remove top cover. Remove and open the black box containing laser. Remove motor board and lube the motor, dont get the mirror dirty. Asseble. Total time 15min...
SOURCE: HP Laserjet 1320 Series Printer-Grinding Noise Won't Pickup Paper
take the roller out again but this time make sure the paper sensor is in the proper place. it does go scew when putting a new roller in. It happened to me last month.
you dont need to get another printer.
SOURCE: how to replace fuser drive assembly on HP laserjet
http://www.feedroller.com/Store/Service%20Manual/HP%20LaserJet%20P3005%20Parts,%20Service%20Manual.pdf
Hi, this is a link to the service manual for this printer. It may help you with replacing the part
SOURCE: HP Color Laserjet 2840
You might find that it is the gear driving the fuser, these plastic gears get very worn when driving the ceramic fuser gear. Right Rear plate assembly RG5-7580 with the gears that connect the fuser motor to the fuser.
