Ipaq 2700 did hard reset of device and cannot access any files on sd card. Attempted to recover with Recuva which successfully found files but now cannot open any of those files. These are "notes" files.
I'd recommend that you download this sd card recovery software called asoftech data recovery, download from link below
http://www.asoftech.com/adr/
Many people save their important data on SD card in their device but unfortunately, problem occurs on SD card and all data stored on it get disappeared. In such situation, you need to use SD Card recovery tool. This is one and only way to recover deleted data from SD card without ant difficulty.
http://www.androiddata-recovery.com/blog/recover-deleted-files-from-android-sd-card
just 6+ years late,wow.
Wondershare Data Recovery, safe and effective Windows data recovery software, retrieves your lost videos, photos, music, documents, emails, etc. from your PC's hard drive as well as from USB drives, external hard drives, mobile phones, digital cameras, iPods, MP3/MP4 players, and other storage devices. Four unique recovery options guarantee to find everything you're missing quickly and easily:
Best Android Data Recovery Software on Windows 8 7 XP
All right! Except Recuva, there are also
other data recovery freeware that could do a good job to restore the
inaccessible data back.
In your case, you could select a special SD
card data recovery freeware and try to restore all your inaccessible files back from this SD card for free.
This freeware really helped a lot as the
data of my friend became inaccessible. This drive finally restored all his
needed data back. I was there, too. It is really worth a shot!
Note: Never try to save the important files
on only one drive or location on the future.
You must try an efficient tool for recovering data. Download a tool from
http://www.freedatarecoverysoftware.org
and recover lost data with actual properties without loosing a single bit of data.
In order to recover
photos from SD card, one should make use of Yodot Photo Recovery software. This
software works so good that you will be impressed by its performance. It recovers
not only photos but also all the files that are present in your SD card. It
provides free trial version. So to know much about its performance, you can
download its trial version. Keep in mind, if you want to recover SD card photos
you should not use it once you realized that you have lost files from it.
SOURCE: rx3715 will not recover from a hard reset
try removing the battery - for a few minutes to begin witj, then a few hours if that doesn't help.
SOURCE: Cannot copy large files to my SD card
Yes , the Activesync connection is not reliable for large files. You really would be best to get a USB card reader, also it would be MUCH, MUCH faster.
SOURCE: Mini SD card
Goto the Start Menu, then down to File Explorer. Hit the menu Softkey and scroll down till you see Storage Card. The other way is if you hit the Up softkey while in /My Documents (where file explorer defaults to), just scroll down and you should see Storage Card. It's easy to tell because it has a small pic of a MicroSD card on the folder. Hope this helps!
SOURCE: ipaq rx3715 won't reset.
The description you are providing indicates the PDA has problems in uploading the booting firmware to the memory.
Unfortunately, this means that it needs a professional technician to open and perform a diagnostics on it to fix it.
It may be a defective integrated circuit, or moisture or humidity that got inside de PDA.
Some times is possible to fix it with minor internal cleaning or with minor replacement of electronic parts, but other times is possible to fix it only with the replacement of the main board.
Bottom line, you need to have a quote for diagnostics and repair of it, and make the decision if is better for you to repair it or buy another one.
Best regards,
SOURCE: IPAQ 6365 hard reset
I Also Had The Same Problem. Now I Fixed It. Go To Power In Settings. Click On The Advanced Tab. Uncheck The Box Which Says "Turn Off The Device If Not Used For" Box. This Will Solve The Problem. It Solved Mine. Thereafter Once, My Backlight Did Not Switch On. Fix This By Going Into Backlight Settings And Uncheck The Box Which Says "Turn Off The Backlight If Not Used For" Box. This Will Solve It. Then Soft Reset The Device To Change Settings. To Soft Reset, Find A Small Hole In The Left Hand Side Of The Device. Put Your Stylus In And PRESS ONLY ONCE. If You Keep It Pressed, Your Device Will Hard Reset. Don't Do That. Just Press ONCE.
First of all don't worry! It is very common scenario. Most of us commit this mistake. You can recover all your deleted photos from SD card in a few clicks process. I also suffered with the same problem a few days back. Because Photos that I lost was very important for me. After a lot of internet search I got a software for SD card picture recovery. It is simple to use and you can download from here . It is free of cost. Face any problem drop me a mail.
try this one
