Xantrex Technology Heart Freedom 20 12 Inverter Logo
A
Anonymous Posted on Dec 20, 2012
Xantrex does not charge inverter is not working solar charger is not working
5 Related Answers
Anonymous
  • Posted on Sep 08, 2009
SOURCE: Xantrex Freedom 458 Combi inverter/charger 2000 watt
OK my 2000 Discovery does the same thing. Try and hit the inverter charger with your fist 3-4 times, then listen and see if the charger fan starts up. I will be bringing my inverter to Portland this week to have the tech look at it. The other thing is it could be the transfer switch. Will let you know.
nitrospawn
Ibe Chukwudi
  • 290 Answers
  • Posted on Feb 26, 2010
SOURCE: Heart interface 30 marine quit charging
the charge fuse may have broken or the charger is bad
nitrospawn
Ibe Chukwudi
  • 290 Answers
  • Posted on Feb 27, 2010
SOURCE: inverter won't charge
check if the inverter has a fuse for the charger, if it does test it if it is still ok if not change it
Anonymous
  • 17 Answers
  • Posted on Sep 27, 2010
SOURCE: can't get my 84-2056-01 to work the inverter
This is over a year old, so presumably you solved your problem, but for reference for anyone else reading, the only connection between the inverter/charger and the remote panel is the RJ-11 phone type jack through which the remote panel also draws its power. Just make sure it is firmly seated (until it clicks) on both ends and that the wire is not crimped, cut, or chaffed in between. Otherwise, likely a defective remote panel.
Anonymous
  • Posted on May 14, 2011
SOURCE: I am trying to fix my xantrex freedom 10
my 458 will not allow 110 volt power in my boat..the 12 volt circets work fine ..is there a switch in the 458 that might be stuck??
Xantrex freedom 2000 watt inverter/ charger
Hi
Your x anter freedom inverter can't run all those items it is being over worked ( overloading ) that's why it is heating up and if not carefull wit will explode .
Xantrex inverter/ charger smells like burning electrical
I would call or e-mail the manufacturer of the inverter. The dealer or dealers may know the issue but likely the manufacturer will be more help.
Some devices like an inverter will have a smell in the beginning, power supplies are like that. You said that the inverter didn't get hot but smell indicates something is hot.
Xantrex model rs2000. just purchased used. owner said all worked. got wired up, charger does not operate, shows no external power source, (led not lit). checked power to unit, at 119-123 acv.. inverter...
If it shows NO external source, then this is most likely the best place to look to find out why not?
http://www.ehow.com/how_7519715_troubleshooting-ac-inverter.html
Now above is a link that show you how to troubleshoot an AC inverter. Now below, there is a service manual, here at the back, is a factory troubleshooting chart that will be beneficial to you.
www.xantrex.biz/...Inverters/.../XS400_Owner_Guide(975-0054-01-01_Rev- B).pdf
The Biggest problems with Inverters is Flat/Low/Bad batteries, Sometimes it pays to remove the batteries and charge then up remotely, and then replace them, fully charged, Now a fully charged 12 volt battery should have 13.8 V DC at the terminals with NO LOAD. If the battery only reads 12 V it is not properly charged.
Xantrex 458 freedom....has stopped charging house batteries off of engine alternator. Alternator is showing that it works (dash gauge). It does charge while on shore power or generator....but not charging...
Fis\rst of all is the inverter supplying 120 VAC? when turned on?. If so the inverter seems to be working.I think your problem is in the truck alternator/charging system. The inverter is independent of this charger..
2answers
I have a trace inverter DR 1512, I am having a problem with my system, which includes a 5000 watt gen, and solar power. When I am dry docked and have solar, system functions fine, when I lose solar and go...
the solar panel is just to charge your inverter,if it is charging and the inverter is on it will drain the current the solar panel is supplying to the batteries,this makes it look like it is not charging ,so i advice you to switch off you inverter when charging it,get another set of batteries connected to your solar panel then charge both, let them be separated so that the new one is not in use so that when solar is out you can switch to the other set of batteries
Inverter output voltage (eg. 96 volts) not if this is an issue
96 volts is low. 106 volts is low. You need to be about 110 to 120 volts optimum. How is your battery input? This is crucial for the inverter to output correctly. If it needs 24 volts DC in Then make sure it's 24 volts. 48 volts means 48 volts. Check the battery voltage and compare to inverter input requirements first.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
2answers
Inverter won't charge
1helpful
5answers
Power Supply How To
Because inverters operate from a DC (Direct Current) power source, usually a battery bank (one or more batteries), the battery source will have to be recharged at some point. (Remember that a battery discharged more than 50% is probably close to being dead.) Most cars and trucks recharge their batteries from an onboard alternator. Depending on the inverter load and runtime required, most power use applications will be covered by the charged battery, augmented by the operating alternator supplying a continuous charge to the battery. If the load is large (air conditioner, large draw power tools, large microwave, food freezer, ice cream machine, etc.), the user should verify that the installed vehicle alternator is of large enough capacity to operate the vehicle's power requirement as well as to fulfill the capacity of the inverter load. If it’s not, a motor throttle installation may be required to carry a small load, a larger alternator may be required, or a larger alternator, battery isolator and additional onboard battery bank may be required in order to meet the power requirement of the large load. Remember: it takes 12 DC Amps (at 12 VDC) to run 1 AC Amp (at 120 VAC single-phase) of power because there are voltage and efficiency factors to take into consideration.
Top Xantrex Technology Boating Experts
vince
ADMIN Andrew
ADMIN Andrew
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
