One possible source of difficulty is there are different blanks for
"slow" recorders (1x - 4x), "high speed" recorders (4x-10x), "ultra speed"
recorders (12x-24x), and "ultra speed +" recorders. The disc manufacturers
had to change the way the discs were made to accommodate each successive
improvement, so older recorders don't work with the newer disks.
It is possible for some 4x-capable "slow" drives to use the "fast" blanks
with a firmware upgrade, but there is no advantage to doing so since you're
still limited to 4x recording (unless, of course, you're unable to find
"slow" CD-RW blanks).
CD-RW discs for the faster drives are labeled with a "High Speed",
"Ultra Speed", or "Ultra Speed +" logos. Make sure you buy the right blanks
for your drive.
Yes it should be able to read any CD including music if you have software to play back music with. There is something wrong with the reading head on your CD player.
I hope this helps you out and if it does please leave me some feedback.
make sure that the cd rw is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might bebad/faulty or your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd rw then plug them back in this will activate found new hardware wizard hope this helps or you might have to uninstall then restart your computer then reinstall your cd rom or uninstall the driver then reinstall for this device also click start control panel administrive tools computer management device manager scroll down cd dvd rom drives right click you can you will have options to update driver roll back driver select properties general troubleshoot select driver click to reinstall drivers click update driver uninstall then reinstall you need only do the registry check if you cant see the drive/s in windows explorer/my computer it might be a registry problem Close all open programs
Click on Start, Run, and typeregedit and press Enter Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor Reboot your computer Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. hope this helps
If the drive is not working then it will need to be replaced. Check to see if the door opens & lights come on after loading a disc. If they do then it is more likely a driver issue. You can try to uninstall the drive in device manager and then reboot to see if Windows identifies the drive and installs the driver. If the drive is dead then replace with a compatible drive. Hope this helps.
Hi there, as per your information the device working well. But not read CDs. So i suggest you install a CD/DVD Reader or rewriter software.
Because, with out the software your DVD/CD device can't able to read CDs. You can use Nero Express software for solving your problem.
Thanks & waiting for your feedback.
The problem is that at some stage you or someone else forced the cd open or closed, but not to worry, it's not broken. What happened is that the gear that pulls the tray in, mite have slipped a tooth or two. You'll have to open it up. Take the top cover off. It has four small screws holding it. When you take the cover off, the gear system should reveal itself. Now the gear that pulls the cd tray in and out must me ajusted. Before you open the dvd writer, make sure it is in it's utmost closed position. Very Important!. There should be a screw in the centre of this gear. Carefully unscrew completely. Now it depends on which direction the gear turns when it close the tray. Seeing that it doesn close completely, the gear turns anti clockwise to close. Lift the gear in a up sliding position and turn it one teeth clockwise, press the gear back, fasten the screw and test. If it still needs more adjustment, repeat the process with another teeth clockwise. Note if it worsen that it doesn't close, then you need to reverse the process and move the gear anticlockwise, but make sure to mark the teeth that it was originally on when you opened it.
it seems that your cd rw burner has reached it's MTBF, or it might have even over lasted it, I myself experienced such problems and the only way to solve it is to replace its read write assembly as a package, it is available at all LG computer peripherials store.
yes,it was detected by my computer
is the writer was detected by your computer, did u see it on the device manager.
