Kodak EasyShare C300 Digital Camera Logo
Jamie Howard Posted on Jun 16, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blurry Camera i have a c300 kodak digital camera and whenever i take a picture the display screen is always blurry! I can't take pictures anymore without it being blurry!
  • Jamie  Howard
    Jamie Howard Jun 17, 2007
    thank you for helping me!
  • Anonymous Mar 16, 2014
    pICTURES ARE TURNING OUT BLUUUUUUURY......NO MATTER INDOORS OR OUT IN BRIGHT SUNSHINE.....AND NOT IN A MOVING VEHICLE/BOAT KAYAK/ROCKET/ JET/SKI BOAT/OR BUNGEE JUMPING....
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 28, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
913
Points
I have a kodak c300 digital camera Whenever i take a picure it is blurry on the display and it comes out blurry off the chip
Anonymous
Level 3:
Genius:
  • Master 2,985 Answers
  • Posted on Jun 17, 2007
Anonymous
Master
Level 3:
Genius:
Answers
2985
Questions
0
Helped
1027513
Points
5636
Are the images coming out blurred from the card? Check that you have not inadvertently set it to Macro- read the manual through. Tell Kodak Technical Support team about it. especially if it is a young camera. A new camera may be in the offing unless it has become damaged, in which case it will be a new camera- that you pay for
Blurry screen and pictures
sounds like the camera was dropped, if you look ate the camera from the sides, and the lens don't look square to the camera body, grab the lens and force it into alignment, you might hear a little POP, and thats sometimes good..BUT call your local camera shop and ask what the average cost to repair ? and always check your camera for recalls !
Jay the pump repair guy
4helpful
3answers
Pink colored pictures from my digital camera
For this problem try doing the ff:
  • transfer the photos to the computer
  • set the camera in auto mode
  • take a picture
  • if the picture is still pink and blurry even after transferring to your computer
  • call the tech number 18002356325
Thanks
Byron
2answers
My kodakm863 has a blurry screen constantly so all pictures are blurry what can i do?
Try to set the camera mode in to auto
Make sure the flash is set to auto
Take pictures in different lighting condition outdoor and indoor
Try do transfer pictures in the computer format the memory card and the internal memory
If the pictures appears blurry the lens assemble on the camera or the sensor is defective...
1helpful
Blurry Display Screen and 2 beeps with shutting Off
check the mode that the camera is in try to put it in auto mode, if its in other mode like fast motion etc it can cause this blurry pictures
2helpful
The Same problem
I'm not sure why this works for me, but I think it's worth a try:
1) First, take your SD card out of the camera.
2) Then turn on your camera and let it turn itself off.
3) Read the next step first and be ready to press the shutter release button (take a picture) right after the LCD screen turns on
4) With the camera lens pointed down towards the floor (aim down), turn on the camera. At this point the LCD screen should not be blurry anymore. Immediately press the shutter release after confirming that the LCD is not blurry. If the camera stays on and you can review the picture (most likely of your feet), then you are almost done.
5) Turn off the camera and re-insert your SD card.
5) This may not be a permanent fix, but point the camera lens downward whenever you turn on the camera. It should work normally if you do this. Mine worked normally (meaning I don't have to point it downward when I turn it on) after doing this several times. Your results may vary.
10helpful
2answers
I have a kodak m1033 turns on then shuts right off
1helpful
My camera was dropped, and the screen adn pictures are all blurry
Try going to a camera center. They have the expertise on that matter. They can also tell you to how much is needed to get it fixed.
Kodak camera has blurry pink display when taking pictures
mine has the same problem. it's less than a year old. nothing in the manual mentioned these kind of erros.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
