LD 118d
SOURCE: cannot send email from a Canon 3380i
Most likely you will have to log into the machines interface by putting the machines IP address in your web browser. Once there you will have to put the new email settings in the machine so it can email properly.
SOURCE: Canon imageRUNNER 5000 scanner
yes it can if you have the scanner driver borad loaded in the machine
Thank You,
Mikey
SOURCE: Ricoh Aficio 1075 - SMTP error message
To use the scan to email function on your copier you need some settings from your internet provider (email setting specifically). Go into Outlook options and get your SMTP server, user name and password.
On your copier you need to change under User tools, system setting and file transfer and put these settings in. As long as your machine is set up for scan to folder thats all you should need.
SOURCE: Can't scan to email for a Canon ImagineRunner C2550
You need to set the scan settings in copier settings 200dpi 300dpi color or black and white....
SOURCE: How do I scan a document to send as an attachment
First your company must have a e-mail server.Enter the server ip address in the smtp server address in the additional funcktion,system settings,network settings page untill you get the smtp server address.
