MY ACTUAL LAPTOP HAS CRASHED, I CAN NO LONGER USE THAT PARTICULAR LAPTOP. PRINTMASTER 2011 WAS DOWNLOADED ON THAT LAPTOP. I NOW NEED TO DOWNLOAD ON MY SECOND HAND LAPTOP.
SOURCE: can you download broderbund printmaster gold
Please check if the version does support your operating system (ex windows XP)
If it does, then you have no problem installing it on your laptop.
Have a nice time over there
Please rate my answer
SOURCE: cannot install PrintMaster Platinum 2011 When I
Today I tried installing the same software with the registration key #. It kept saying the number was not valid as well. I typed in "O"s instead of zeros. When I typed in the zeros the software allowed you to go through with the installation process.
SOURCE: I WOULD LIKE TO CONVERT
If I was in your place I would use a direct connection if both computer's are connected to the internet ...and in the same default gateway ..its easy ..cause you can find the other computer into my network places folder..after you select the view workgroup computers task ...You will have to disable the firewall in both machines and after that you will have access on the other computer just like in my computer folder..and copy files...
If they are not on the same workgroup...than you can use a remote control program to transfer the files directly ..THis one will do the job ..,all you have to do is to install it on both machines ..open in the remote one ..and in yours..and get the ed and password offered by the program and connect to it ..after that you basically have ful access to it ..even tranfer files..
here is the program :http://www.teamviewer.com/index.aspx
If the machines are not connected to the internet than the only way is to use a large memory stick or an external hard drive ...or just get the hard drive from the one you need the files and connect it temporary to the other one ..and you will find its partition in My computer ..after that just copy paste the files in the other partition from the computer you intend to use..
SOURCE: my printmaster 2011 gold won't
Installing printmaster 2011 gold on PC.
System Requirements:
Windows XP (Home & Pro) SP3/Windows Vista SP2/Windows 7*
Pentium IV 1.6 GHz or better (2 GHz recommended) or comparable AMD Processor
1 GB RAM available (2 GB RAM or more recommended, 2 GB required for Windows Vista and Windows 7 users)
Available Hard Disk Space: Installation disc requires approximately 2.7 GB; downloadable content can require up to 36 GB of hard drive space
Internet connection required to access content 16 MB Video RAM (64 MB video RAM recommended)
DVD-ROM drive, keyboard and mouse
Monitor resolution:1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (Available at www.quicktime.com)
Java version 6 or higher required (available at www.java.com)
Recommended Additional Equipment:
Printer, Digital Camera
Macintosh OS X 10.4.8 or greater* (with the latest Java update)
PowerPC G4 500 MHz or faster (G5, PowerPC or Intel Mac--1 GHz processor or better recommended)
Available Hard Disk Space: Install disc requires approximately 3.0 GB; downloadable content can require up to 36 GB of hard drive space
1 GB RAM (2 GB RAM or more recommended)
8 MB Video RAM (64 MB video RAM recommended)
22 GB (hard disc space)
Monitor resolution 1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (available at www.quicktime.com)
*Administrator privileges are required to properly install the program on Windows XP, Windows Vista, Windows 7 and Mac OS X
Do your system meets the above requirement?
SOURCE: I can't load my PrintMaster
Welcome to Fixya
As much as we wanted you to assist on this, but we cannot provide you or give you alternate product key for your software. You might need to contact broderbound for this. The product key that came with the CD should be working with the software.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
