I need to replace my oil sending unit
The fuel level sending unit is located on the fuel pump assembly on a 2005 Nissa Altima.----------------------------------------------------------------------------------------
Odometer Correction Tool
SOURCE: where's the 2005 kia sedona transmission dipstick located?
Looking at the motor from the front it is on the right hand side , it is down pretty low so it is hard to see it , always check fluid when hot and the van is on level ground and is running also
SOURCE: Need location of inner belt tensioner for '05 Kia Sedona
It is below the power steering pump pulley, there is a nut in the middle of the pulley that you loosen and then loosen the tensioner bolt to move the pulley away from the belt.
SOURCE: 2005 kia sedona ECU replacement
It's located at the passenger side behind the air conditioner plastic duct (inner firewall)
SOURCE: How to change the oil on a 2005 Kia Sedona
The oil filter is towards the front of the car, underneath on the passenger side, at the corner of the engine cradle. Loosen the drain plug and drain the oil. Make sure the old oil filter gasket came off with the oil filter. Reinstall the new oil filter. Reinstall the drain plug and fill with 5 quarts of 10w/30 motor oil.
SOURCE: where is the oil pressure switch located on a 2005
RIGHT ABOVE THE OIL FILTER ROUND CONNECTOR
