Question about Razor MX500 Dirt Rocket
Batteries are charged and the bike doesnt work any ideas on what it might be and batteries are new
    New Friend:
  • 15 Answers
Yes! if that's the case ,the motor is the culprit.there are 4 things that make our bike run..the a good charger, batteries, the throttle, and the motor. now that you singled out your battery and charger ,you have the throttle and your motor..1st check your throttle & make sure it stops @ a1/4 twist.check all connections, then do an extencive check of your motor for moisture or water/signs of it being wet/riding in the rain..which is a big No-No../no rain No snow, No drizzle,and no puddles clean or muddy..it is not a gas bike....remember!great tip!
Posted on Dec 30, 2012
6ya staff
SOURCE:
Electric start doesnt seem to be working
If there's no noise at all your battery is either dead (jump start or new battery). If it clicks then there isn't enough charge in your battery to start the bike (charge battery or bump start)
Jan 06, 2014 | 2004 Honda CBR 125 R
The bike dies, after a fully charged battery.
Bike has magneito (thats spelled wrong ) On line youtube veido shows how to fix that.
Apr 01, 2012 | MBK Motorcycles
I just bought a new battery for my 2005 Softail Deluxe; I road yesterday (10/20 miles) as I was finishinng the run, the bike shut off; could this mean the battery was not fully charged? Will a trickle...
Good idea put it on a trickle charge, however, the battery had enough charge init to start the bike initially, and the bike should have charged the battery after 10-20 miles, worth checking the charge rate to the battery from the rectifier,
Apr 25, 2011 | 2005 Harley Davidson FLSTN- FLSTNI Softail...
Bike engine light came on shut bike down wont start battery level is 10.6. Everytime I try to start the bike I get a code 0005 raw or so I think that's a code anyway. Any ideas what's wrong oh I checked...
Battery needs to be over 12v for the bike to start, with the bike running it will be about 14v
if you charge the battery and it wont hold 12v----new battery
If the bike starts and doesnt show 14v aprox---- new regulator
Apr 11, 2011 | Ducati Monster 696 Motorcycles
My Ducati 750 Monster Battery is Dead. What kind ...
A smaller car 12v 4 or 5 amps charger will do the job, the slower the battery is charged the better, so use the lower setting if available.
charge it out of the bike, this way you can check the water level, and if it overflows it wont spray acid over your engine and frame.
If it doesnt start the bike after a charge, get a new battery, as running a sad battery can overload the charging electrics. and dont jump start it of a car battery that will accept more amps than the bike can produce
May 20, 2010 | 2000 Ducati Monster 750 - Dark - City -...
Honda XR125 L-4 3 month old battery, Bike has engine has started to die, exhaust goes pop (backfire?), engine cuts out all together, battery almost completely dead wont restart bike, starter just clicks...
put a volt meter across the battery terminals, should read over 12v stopped and rise to 13.5v with the engine running.
If the voltage doesnt rise there is a problem with the charging circuit.
Be carefull starting from a car, as this can cause damage to the bikes electrics, as the bike tries to produce enough amps to charge up the car when the bike starts, and overcook electrics.
Apr 19, 2010 | 2002 Harley Davidson FXD Dyna Super Glide
2002 gsxr 600 bike shuts off
Did you put a full charge on the battery b4 you put it in? The charging system really dose not charge until like 4 or 5 thousand RPM's. So just starting it in the garage doesnt really charge the battery. Put a full charge on it and it should be fine.Also buy a trickle charger. It will keep this from happening again. Its a commonly over looked issue. If it dies again going around town the replace the stator. ( left side of motor )
Sep 05, 2009 | 2002 Suzuki GSX-R 600 M
Kawasaki zxr died after a run.new battery
try checking your charging system. i would start with regulator/rectifier. they're common to go out.
Jun 14, 2009 | 1990 kawasaki ZXR 750
My battery isnt getting charged on my motorbike from engine
Hi and welcome to FixYa,
Almost always, your described problem indicates a charging issue. This points to the bike's battery not charging. Suspects would be:
  • voltage regulator (most likely);
  • connectors to voltage regulator (likely). Check/clean corrosion/burnt marks;
  • stator and/or the wires coming from it (least likely).
A CDI is a capacitive discharge ignition. This is an electronic module that fires the ignition coil.
Parts would depend on where you are. Often, other riders would provide information for parts source.
Good luck and thank you for using FixYa.
Feb 25, 2009 | 2002 Yamaha TT-R 250
Charging
Try new charger. Else send it back to manufactures if it's still under warranty.
Apr 26, 2008 | Samsung SGH-D900 Cellular Phone
Razor MX500 Dirt Rocket Logo
218 people viewed this question
Top Razor Cycling Experts
Lawrence Oravetz
Wayne Fraser
ray gallant
ray gallant
Are you a Razor Cycling Expert? Answer questions, earn points and help others
