The Timer blinks once, the LED blinks once and the Standby/Temp blinks once. The LED then starts blinking continuously until it stops and the SB/TEMP goes solid. Any ideas?
SOURCE: TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
SOURCE: Samsung DLP TV time, temp and lamp lights blinking... won't turn
Les,
I'm not a TV repair guy but my owners manual states that when all three LED's or lights on the front of the TV are flashing, that the lamp needs to be replaced. Might want to look into this. Good luck!
Greg
SOURCE: I own a Samsung HL-R5067W 50
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
SOURCE: My samsung 5067w dlp tv does not turn on, the
First check the color to see if its spinning or not. Replace it if neccessary. If that's ok, replace lamp and ballast.
