With a wireless connection, your PC can connect wirelessly to a network printer. In addition, you can set up your PC in a location where no phone line or cable connection exists. Outfitting your desktop to a wireless Internet connection is very easy. Just follow these simple steps and you'll be surfing the net wirelessly in a matter of minutes.
Find out if wireless Internet reception exists where your computer is located. If you're located very close to a W-iFi hotspot, like a coffee shop, you may be able to use this network to get wireless Internet for desktop PCs. Also, some apartment complexes and college dorms have free wireless Internet. Your neighbors may have wireless Internet too, which you can ask them if you can use. Buy a wireless network adapter for your desktop. You can obtain an adapter from most electronic stores. Be sure to get a wireless adapter with the proper strength, which depends on how far you are from the wireless hotspot. The easiest adapters to install are those that just plug into an available USB port. Set up your wireless Internet for your desktop PC according to the instructions that came with the wireless adapter. The usual procedure is to plug the wireless adapter into an available USB port. Windows will install the appropriate driver. After your PC recognizes the wireless adapter, select the "Connections" icon in the taskbar (represented by vertical bars). A list of available connections will appear. Select the desired connection. If you are prompted for a password, enter the appropriate password. Click "Connect." You are subsequently connected to a wireless network. Launch your browser and enjoy surfing the Internet wirelessly. If you are the owner of the wireless network, secure your wireless network with a password. To do so, navigate to the "Start" menu and select the "Control Panel." Then select "Network and Internet" and "Network and Sharing Center." Click "Change adapter settings" in the left pane. Double-click the icon of the appropriate wireless connection. The Wireless Network Connection status window appears. Click the "Wireless Properties" button. Select the "Security" tab and select an encryption type from the drop-down selection. Enter a password in the Network security key field. Make sure that the password matches the router settings. Press "OK" when done. Get a wireless internet router for your Internet connection if there is no wireless Internet already in your area. You can buy these online, or at electronic stores. You'll need to set up your router using the accompanying instructions and your own Internet service provider. This is best in a home with multiple computers. Hope this helps
SOURCE: i have an dell inspiron 530s desktop what types of
Go to "My Computer" - this should be an icon on the desktop. Right click on the icon. Choose "Properties." Click on the Hardware tab. Click the "Device Manager" button. Navigate to the "DVD/CD-ROM" drives + sign. Click on the plus sign. Read about your hardware.
SOURCE: Dell inspiron 530S built-in camera problem.
have you tried going to www.dell.com/drivers and see if you can get a new driver for it
SOURCE: my usb ports dont work on my dell inspiron 530s,
Hi there.. i just got the same scenario when i reformatted mine.
Here's how i solved it:
1 - im using winxp and used restore cd to format it then i install winxp sp3 patch.
2 - download and install latest drivers of my devices from website.
3 - install anti-virus and other software. good to go.
SOURCE: Dell Inspiron 530s/531s desktop, Win. Xp
try to boot in "Last good known configuration settings" by restarting your pc and then press F8 before windows appear and then select the boot option i mention above. if this not work since you said that it can't boot to safe mode, your other option is to repair the windows or else reformat it. when you repair the windows you must have windows xp home edition cd installer, you load it to your cd/dvd rom and then restart your pc and press F2 or DEL button before windows appear in order to go to setup bios settings. in bios settings, you choose boot order setup and setup first priority to cd/dvd and press F10 by saving the changes and then press any key when you see the prompt so that it can boot up to windows xp home cd installer and then follow screen instruction that you arrive to windows repair option.
