Cars & Trucks Logo
A
Anonymous Posted on Feb 26, 2018
2002 silverado 1500 hd won't start
It is a cold day, truck started fine this morning, went to start it 4 hours later and nothing, the lights and music come on but the motor will not start when I turn the key. The fuses have been checked, a new battery has been put in, alternator seems fine, is it the starter, ignition?
Jeff Armer
Level 3:
  • Chevrolet Master 15,575 Answers
  • Posted on Feb 26, 2018
Jeff Armer
Chevrolet Master
Level 3:
Answers
15575
Questions
Helped
7111242
Points
73899
When you turn the key to start does the starter engage an spin the engine ? or nothing happens .
the lights and music come on but the motor will not start when I turn the key ??????? Will not start how ?
crank - no - start or no crank no start . ????????
5 Related Answers
Anonymous
  • 6982 Answers
  • Posted on Mar 18, 2009
SOURCE: 2001 chevy silverado 1500 v8 battery drain after sits for 1or2day
, do a simple test on the charging system...check battery voltage. should be 12v or better. start engine & check volts at idle, no accessories on. volts should read 13.5 -14v. Turn on all accessories(including headlamps on high) volts should drop slightly but should not creep down. Definitely not below 12.5. If voltage drops lower than 12.5, the regulator (in the alternator) is not working. either change regulator or change entire alternator. Alternator drive belt should have sufficient tension so that alternator cannot be turned easily by hand. If it can, check belt tensioner.
Anonymous
  • 209 Answers
  • Posted on Apr 21, 2009
SOURCE: Suburban won't start, we don't believe it's the starter
first try to check the fuse of the ignition if it is ok or clean coz some times when it has a corrosion it has the tendency of having a delayed power transmital . if it is fine then check the starter relay if it is good coz it also having a power surge so you have a delayed power to your starte...
Anonymous
  • Posted on May 22, 2009
SOURCE: won't start, good battery,
For as long as I've had my 2001 silverado I have ran into this same problem.. And of all things it may be that the battery lines and or post may be corroded and or the posts not fully tightend... Once I took care of those 2 simple things... All has been good
co7196
Ned C Cook
  • 3433 Answers
  • Posted on Jun 03, 2009
SOURCE: 1989 Chevy Silverado C 1500 Truck
The ignition switch is mounted on the top of the steering collumn, and is connected to the switcth with a rod. Top of column down by the pedals.. Remove and test switch.
Anonymous
  • Posted on Aug 24, 2009
SOURCE: I have 1998 Chevy Silverado with over 200,000
I have a 98 chevy silverado also. I had same problem. My problem was located in the battery terminal. You need to take the terminals screws off and clean them good. You can not tell by justing looking at the terminals from fixed position. The corrosion was on the thread of the bolts itself.
Murray m2500 won't start after one day of having it
bad coil in it, i had bought a m2500 murray weedeater from walmart .did same thing i replaced the coil. bad when you buy something from wal mart and have to get it fixxed before you can use it. now it works fine
Chevy 2000 Silverado 1500, the engine stalls and won't start until it has cooled off.
You'll have to figure out if it is a fuel or ignition problem.
Is the check engine light on ?
The car turns over like it is going to start but won't. It is still firing, has good battery, alternator and gas in it. It is a 1996 plymouth neon. Started fine when I went to work this morning, b
tell individual working on it to check the crankshaft sensor voltage and signal when it wont start also check the fuel pressure and cam sensor, these are all possible problem with that particular car. it also has wiring issues that an expert tech would have to diagnose
Took radio out now truck wont start.security light stays on,won't flash at all. tried deactivating passlock can't, also domelight,hd lights,l/door lock, keyless kemote not working. all this fr
Ypur security system is armed, if you was try unlock procedure from owners manual and wont work, its possible that you will need visit your dealer to reprogramming.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
My 2003 chevy tahoe won't start in the morning
Many possible causes....Too little info to make an intelligent suggestion. Try charging the problem vehicle's battery with jumper cables for 2 minutes with the supply vehicle running at fast idle (or about 1500-2000 RPM, if it is tachometer equipped) before you try to crank the problem vehicle on a cold morning. If it starts right up, you likely have a weak battery that needs replacing.
My car has been running fine. Starts each morning once to drive kids to school. An hour later for me to drive to work. But for the last two mornings won't start back up after working 4 hours. I noticed...
Sounds like the alternator is going out the slow way.
Youre kinda lucky because almoat all alternators go out without warning.
Most Autozone shops or places like it will run a test for free.
Good luck,Gary
Car was rinning perfect. One day it would not start. there was nothing, no clicking ,bell and guages were working. Jump start was nothing. Installed a new battery there was nothing. Went bact back 2 hours...
It sounds like you have an issue with your PassLock security system. I had the same with my 2002 Impala. Key turns OK, but won't start, won't crank. Wait 20-30 minutes, and car starts normally. There is usually a clue from the Battery and Security lights.
The problem starting to happen once a month, and eventually 1-2 times a week.
There are several write-ups on this problem for several GM cars for 2000-2006(?). Search this website, and search the web.
The official solution is to replace the ignition switch. The best solution is to bypass the Pass Lock system. I went ahead and did a full bypass, which involves cutting wires and adding resistors to the ignition circuit. I have not had a problem since.
2answers
I have 1998 Chevy Silverado with over 200,000 miles. One morning I started it up just fine, backed out of the drive way, and it just died. I turned the ignition to off, and turned it back on and parked it....
Check your battery terminals. They may be corroded or just loose. If you get it running again have the battery and charger tested at an Advance or Autozone.
Hope this helps.
Rich
2000 Dodge Ram 1500 (V8 5.2L) will not start
could be the battery, sometimes all the electrical would stay on but the battery doesnt have enough juice to crank the car over, if not check the alternater.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
