Question about Nintendo Wii Fit - Balance Board + Game Console
Won t turn on with the wii fit game replaced batteries twicw
The blue light won t stay on on the board so we can play wii fit
    New Friend:
I AM NOT GOING TO AWNSER YOU Q BUT I CAN TELL YOU THAT THAT IS THE SAME THING THAT IS HAPPING TO OUR SO IF YOU GET THE SOLUTION BY ANY CHANCE WILL YOU LET ME KNOW
Posted on Aug 20, 2013
SOURCE:
SOURCE: wii fit balance board
You need to sync the balance board with the console. Instructions are in the manual. Sync button for board is in battery compartment and sync button for console is in panel under reset button.
Took a few tries for me, be carefule not to hold sync button on console down for longer than 10 seconds because it will deregister all wii remotes.
Posted on Dec 23, 2008
SOURCE: wii fit board wont sync
Ok I feel a little silly, there is a sync button on the console (inside the flap by the power on button) and the board (inside the battery compartment on the underside of the board) as soon as I pressed them at the same time it worked. Goodluck everyone.
Posted on Feb 09, 2009
cene765
  • 787 Answers
SOURCE: my wii fit board will not turn on. when button is
Re sinc it.Open the front cover on your Wii and push the red button there, then open the batteries cover on your Wii fit and push the red button there.If this not help Open thre front cover on your Wii and push and hold the red button for 20 seconds.This will clear all sync devices.Now try again to sinc Wii fit.In this case you need to sinc your WII Remote/s again too.If and this not help may your Wii fit need service.
Posted on Oct 23, 2009
  • 141 Answers
SOURCE: My wii fit board will not stay on when I press the
The WII Fit board will only stay on, if there is a game loaded and waiting to access the board. For instance, the WII Fit game will prompt you to turn on the the WII Fit board. If you turn it on before prompted, the WII Fit board will turn itself off.
However, assuming you do not have a hard ware problem and you have already put in fresh batteries. you may have to resync the WII Fit board and the WII. Try pressing the red button on the WII Fit Board (near batteries) and the WII itself (near the SD card slot).
Posted on Nov 02, 2009
scott7777
SOURCE: Wii Balance Board Lights won't stay on
Well - had the same problem, even got a walkthru from Nintendo Support. I was ready to pack it to ship off when, demonstrating everything I had done to a friend -- the darn thing started working again! I think what was going on was the sync was "poor" with the console -- it could sort of see the balance board but not enough to actually work. I did the red-button-on-the-board/ red-button-on-the-Wii thing (press board button then quickly press the console button) several times until it "took" solidly. Don't give up -- keep trying. Yeah their hardware/software has a bug......
Posted on Jan 09, 2010
MY WII BALANCE BOARD IS CHARGED BUT THE BLUE LIGHT WONT STAY ON.
  1. Insert a Wii Balance Board compatible game disc in the Wii console.
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the syncronization is complete.
click here to download repair guide if u want
Dec 15, 2010 | Nintendo Wii Fit - Balance Board + Game...
My wii fit balance board keeps blinking but will not stay on. batteries are good. cant find my instruction book. what could be my problem????
follow this
Jul 20, 2010 | Nintendo Video Game Consoles & Games
I can't sync my board to my remote
You have to insert a wii fit game and bypass all the stuff until the game is ready to play.Open the battery compartment on the Wii board and open the large door on the front of the Wii console.Press the sync button on the board,then press the sync button at the top of the console compartment.The fit board light should stay steady blue.If it doesn't,try it again.When the fit board stays steady blue,it is synched.
Jul 13, 2010 | Nintendo Wii Fit for Wii
Our Wii Fit Plus will not recognize sensor to play. Light blinks for a few seconds then goes out. We tried replacing batteries.
You need to put in the Wii fit game and bypass all the screens until it is looking for play options.Take the battery cover off of the Wii board and open the large cover on the front of the Wii console.Press the sync button inside the battery compartment on the board,then press the red sync button at the top of the open console.If the blue light stays on constant,they are synched.If not,try again.Good luck and Game On!
Jun 23, 2010 | Nintendo Wii Fit Plus for Wii
I have a wii fit board, when you power it up, it
Had the same problem. It's a sync problem.
First, best to double check you have fresh batteries.
Next, turn the board upside down and remove the cover from the battery compartment.
Open the small hatch cover on the front of your console unit.
Now start wii fit from the disk menu item.
Next, press the small red button inside the balance board battery compartment. The blue lights will blink for approx 3=5 sec.
While they are blinking, press the red button on the console (in the hatch compartment).
This should re-sync your board and the light stays lit.
Good luck.
Apr 07, 2010 | Nintendo CTA Digital WI-BBP Wii Fit...
Bought 2nd hand wii fit, have just loaded disc and replaced batteries in board but power light not staying on board, flashes for about 30 seconds and then switches off. Does it need to be synchronised with...
    Hope this helps
    Try these steps!
  7. The blue light will stop blinking and stay on steady once the synchronization is complete.
please leave a good rating and testimonial if you appreciate my help. THNX
Mar 27, 2010 | Nintendo Wii Fit for Wii
My wii fit board won't connect with tv is the blue light suppose to stay on all the time or flash
Hi, thanks for using Fixya!
  • Open the SD card slot on the nintendo wii, open the battery panel on the wii balance board.
  • Press the two red sync buttons on the wii console and the balance board and hold for 3 seconds.
  • The blue light on the back of the wii balance board should flash for 5-10 seconds and then stay blue.
  • If this doesn't work then try changing the batteries and trying again.
If it still isn't connecting then the problem is something a proper nintendo expert will have to help fix.
Thanks, I hope I have been of assistance.
Jan 28, 2010 | Nintendo Wii Fit - Balance Board + Game...
Wii fit platform does not stay switched on after
you need to play the game and then turn it on when playing
Sep 17, 2009 | Nintendo Wii Fit - Balance Board + Game...
Power
    Try these steps!
Sep 09, 2008 | Nintendo Wii Fit for Wii
Nintendo Wii Fit - Balance Board + Game Console Logo
154 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
shevantha perera
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
