I can no longer power up the receiver with the remote. Even with new batteries. It's a factory remote and once the receiver is on, the the rest of the controls work properly. Any ideas?
I just had this same issue. I tried to change the batteries for the factory remote that came with the Onkyo HT-S3500 (remote: RC-799M). Still no luck. It would not power on with the remote, despite the light flashing and the and all other remote function working. If I powered on the receiver manually, everything worked (except power on/off).
I just pushed a button on the remote labeled "REMOTE MODE RECEIVER" and viola, the remote now powers the device on and off and works just like usual. Not sure what the heck happened, but I would suggest pushing that button on your remote.
SOURCE: cant find universal remote code for the onkyo tx-sr605
Your onkyo receiver and remote controller only decodes 4 digit codes so what you have to do is to call the manufacturer of the remote controller it self and ask for the hexa decimal codes for their remote. They should provide it to you coz they're the ones responsible on doing that.
SOURCE: Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
time warner does not supply the codes. the equipment manufacturer supplies the code to the remote makers
SOURCE: Onkyo remote won't control Samsung components.
I got an Onkyo RC-717M remote control. It is the remote that comes with the Onkyo TX-SR706 receiver. It is a learning remote. When i entered the cde for the Samsung Blu-Ray it did the same thing as the other remotes I got from Onkyo, the pause, next / previous track buttons wouldn't work for the Samsung BD-P3600. I used the learning function of the new remote and programmed it to work. It works ok now but it sure was a hassle to get it done. In fairness i should have called Onkyo support but their support hours don't match my schedule.
SOURCE: i need the remote control code (for onkyo receiver
Philips Blu-Ray player codes for Onkyo universal remotes are: 33007, & 33016.
You can download Onkyo universal remote codes with
instructions here.
I hope that helps.
SOURCE: Can't find code for Motorola Starchoice sat.receiver
Hello, I just tried the same thing for about 2 hours on a buddies system. I did find on the internet to try 0000, 0001, 0002, 0003, 0004, to 0007 see if one of these work?
I just pushed a button on the remote labeled "REMOTE MODE RECEIVER" and voila, the remote now powers the device on and off and works just like usual. Not sure what the heck happened, but I would suggest pushing that button on your remote.
