Base not sitting straight
SOURCE: I'm looking for a stand base for my LG 42LC2D. I
contact lg. there should be a # in your owners manual. they will be more than happy to sell you a stand designed for your tv
If you broke one of the base stand screw you will need to do as follow:
Remove the remaining screws of the stand and try to remove the stand, if you cant you will need to remove the back cover of the TV and then you will be able to remove the stand, remove the broken screw and put it all back.
It is pretty easy but if you feel you cant do it let me know and I can give you a detailed step by step guide.
SOURCE: how do i remove base stand on an lg 50pc65 tv to
you have 3 philips head screws in the base, unscrew this and wil be abel to get it wall mounted after that.
SOURCE: i have a tv stand but i ned the base screws i dont
Metric screws either M5 or M6, get them at HD or LOWES for about 35 cents each so you try a lot of different length.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
SOURCE: where can i get replacement
I belive the screws you are speaking of are 5 mill 20 thred per , I have found them at local TV shop. They will give them to you if you ask. IF you can not find them local, e-mail me.
please leave feedback
TvPartsGuy.com carries lots of original pedestal stands for LCD & Plasma Tv's.
https://www.tvpartsguy.com . use coupon code: fixya10 for 10% off your stand.
