JVC AV-32S575 32" TV Logo
Michel Lalonde Posted on Dec 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is that a real problem with the tv itself
It's seem to be at same position on screen all the time
Anonymous
Level 3:
Top Expert:
  • JVC Master 14,553 Answers
  • Posted on Dec 18, 2012
Anonymous
JVC Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2716432
Points
48227
What is on the screen?
Un46c7100 samsung led tv has 2 inch bar on the left of the screen that shows the mirror immage of what it is supposed to.
Unfortunately this is a tab fault caused by the screen itself, only real solution is a new screen
Sanyo tv and i am using 2 inputs and they seem to 'bleed' over. one is a computer input(hdmi) and the other is a cable input(v\pb\pr). in additon to the 'bleed' it has resently starte
No sure what you mean by "bleeding over" It would probably have to be seen in a picture to really know what it is. If you hear zapping that's going to be a high voltage problem inside of the tv itself. It could be the flyback going bad or maybe a grounding problem.
How do you check fuses
Getting the back off safely can be a real issue, most of the time the unit is laid face down with the entire frame around the screen supported BUT WITH NO WEIGHT ON THE ACTUAL SCREEN ITSELF.
One wrong move or downward pressure and the screen can be destroyed and the set with it.
Most sets in that position the base stand if it has one has to come off also or first.
Many sets in addition have plastic snaps inside the edge all the way around(screws it seems in some cases not bad enough)
I use a thin metal putty knife to snap them open.
If all this has scared you stop, have a shop or tech look at it.
URC8803
1) read carefully the instr. manual, normally you must keep the code by ENTER, once you put the codes, if this does not pass problem with the microcontroller or CPU, inside the R.CONTROL.
2) test the contacts cleaner+resolder the wires connector batteries
3) open the r.control and resolder the dry joints in the board. otherwise you must go to the repair shop TV for fix it.
see the diagram.
1helpful
My old Toshiba tv is stuck on widescreen, help..
this a problem with microprocessor signal, this will be difficult for to fix it yourself.
Every signal coming from tv goes to the CPU, you must have high skill for to repair and diagram. I can recommend you to get assistance from some repair shop TV for fix it. see the diagram and you will see the problem difficult.
God bless you
3helpful
I'm trying to fix my 21 inch JVC TV, its on standby mode i detected the problem it was Horizontal output transistor, when i replace it with new one it work but after 24 days it got shorted again so i...
depending on circuit design in some TVs when flyback becomes defective then (1) only flyback gets deffective or (2) flyback & 1 transistor big in size fixed near flyback gets deffective or (3) flyback,big transistor & resistor or diodes or some times ICs will get deffective ..........so flyback replacement is compulsory + which ever components gets deffective ....... usually flyback gets deffective after 4yrs (between 4yrs to 12 yrs depending on TV brand & usuage ) .............so in your case along with horizontal transistor replace flyback also ..................... Remove that flyback from main board ? using marker make a mark (1 dot on knob & at the same line put another dot on flyback --- these 2 dots should be in same line ) on all the knobs on fly back ....now turn all the knobs one by one in anticlockwise direction slowly until it stops .... Then observe from the mark which you made before turning .. --- you will get an idea which knob howmuch it was turned in anticlockwise direction.... now take flyback to electronic shop & buy same type ( equivalent will not work )......at the shop itself check part number , number of pins & their position of old flyback with that of new flyback ----- everything should match 100% - nothing less nothing more .... it should be exact .... check many shops...now turn all the knobs of new flyback in anticlockwise direction very very very slowly until it stops....now fix it to mainboard very slowly & carefully....don't forget to connect red wire from flyback to TV TUBE ...again iam repeating don't forget to connect red wire from flyback to TV TUBE .... Now observe mainboard carefully whether any connector is not connected ....now connect only tv powercord & stay at a distance & switch on Tv for 2 seconds & then switch of immediately....during this 2 seconds TV gets on & led also gets on continuosly (won't blink) & there should not be any smoke or sounds on main board ...this confirms you have replaced flyback without disturbing other components & not shorted any joints..... so now again switch on tv ..wait 3 or 4 seconds ...led will be on but there won't be any picture ... Don't worry ....in the beginning you have observed howmuch knobs on your old flyback were turned in anticlockwise direction....remember..? see your old flyback again.... Now using suitable screew driver turn all the knobs on new flyback in clockwise direction one by one very very very slowly ...untill as it was in old flyback ( approximately ) --- remember TV is in on condition ... means high voltage will be there ... bymistake if you touch any part of the tv .. you will get very severe shock.... So be very very very carefull ..now while doing this adjustment observe what is happening on the screen - how brightness is changing ... Now switch off tv....connect signal ( antenna or dvd or cable..) & again switch on TV ....so now depending on brightness & clarity of the picture ..looking at the tv screen again you have to turn 1 or all the knobs on flyback either in clockwise direction or in anticlockwise direction very very very slowly ..once you start doing this adjustment practically then automatically you will come to know which knob should be turned . in which direction - & howmuch it has to be turned .... But remember this adjustment is very important .. Sometimes it will take 30mins to finalise the exact position.of knobs .. so take your owntime & finalise the exact position of those knobs..then switch off tv ..fix back the tv cover .. then switch on tv again ....that's all .......100% GUARANTEE again your tv will work normally ....vishnuswamy_23.jpg
Samsung LCD tv - Turns on and off by itself.
Since you have another TV with the same problem you can try using an antenna(indoor model ok) to see if the cable is causing the problem. If not return TV before the warranty expires.
Mitsubishi Projection TV Model # VS-50502
The power supply section is having trouble.
Common possibilities are:
- Convergences amps have failed overloading the supply
- High-voltage section (flyback transformer) has failed
(happens sooner or later, about 8 years typical))
- Power surge has popped the power input circuit.
(Fuse, rectifier diodes, turn-on relay etc)
- One of a hundred of electrolytic capacitors has failed short overloading the supply. They dry out with age, are cheap to replace, but hard to find which one it is.
- Or any of many other possibilities.
In short, you need a experianced tech to troubleshoot this.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
