I keep having the same problem return, the display gets stuck and does not respond to touch, after messing with it and restarting it will eventually begin working again. Any ideas?
The 003-319 error on a Xerox 7435 indicates a Video Driver Detection Fail. This error typically occurs when there is an issue with the video driver or the communication between the video driver and the machine. Here are a few steps you can take to try and resolve the issue:
Power cycle the machine: Turn off the machine, wait for a few seconds, and then turn it back on. Sometimes, a simple power cycle can resolve temporary communication errors.
Check video cable connections: Ensure that the video cable (usually a VGA or HDMI cable) is securely connected to both the Xerox 7435 and the device it is connected to (such as a computer or a server). Disconnect and reconnect the cable to ensure a proper connection.
Verify video input settings: On the Xerox 7435 control panel, navigate to the video input settings. Ensure that the correct video input source is selected, corresponding to the connected device. If the wrong input source is selected, it can lead to a video driver detection fail.
Update or reinstall video drivers: If possible, update the video drivers on the device connected to the Xerox 7435. Visit the manufacturer's website or use appropriate software to download and install the latest video drivers. If the drivers are already up to date, you can try reinstalling them to ensure they are properly installed.
Perform a firmware update: Check the Xerox website for any available firmware updates for your Xerox 7435 model. Updating the firmware can resolve known issues and improve compatibility with video drivers.
If the copier works but the touch display won't respond, you will need to have the touch screen panel overlay replaced. That is a very common problem that happens to those touch displays
Call Xerox. The Corporation needs to take responsibility for selling a machine that has toner available. //They should tell you where to get the toner or provide some for you. Start out nice but don't let the push you around; insist if you need to. Xerox can't sell a machine with no toner.
Touch screens rely on drivers. Re-install the drivers.
If this does not work the screen probably needs to be replaced. The screen image does not reflect the state of the capacitance resistance touch function.
Which model of Ricoh are we talking about here? If touch screen is not responding before replacement, re-calibrate touch screen or replace it. I can help you with the calibration code if you require. If the touch screen is not responding after replacement, check whether the replacement lcd display panel was installed reverse as the connectors will not have contact.
format your phone and try to access your phone.if the touch is still not responding then you can find out that there problem. then contact the company service center of your mobile and change the display screen.just go on with the company for changing the display screen for your mobile. they will replace the original touch display panel for your mobile.this is best for your mobile.because some local service may replace some local display. which may affect the other components of your mobile.
The mobile screen would have been damaged or a device connected to your screen my be defected .Try to remove your touch screen safe guard sticker then clean the display. If this doesn't work out for you consult your dealer for replacement of new display.
I think if you push the heated wash and heated dry buttom several times until all the buttoms light up this may fix your problem. You may have different kind of light flashing indicator, but the same solution. Possibly check the sequence switch
