Used to use the drive to watch movies then didn't use it for quite a while. now it does nothing but accept it then kick it right back out. this is my computer
Model Name: MacBook Pro
Model Identifier: MacBookPro4,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2.6 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 6 MB
Memory: 4 GB
Bus Speed: 800 MHz
Boot ROM Version: MBP41.00C1.B03
SMC Version (system): 1.27f3
Serial Number (system): W8813042YK0
Hardware UUID: 1CC554EE-91AE-527A-B9EB-549A9024303B
i think this is what the disc drive is
HL-DT-ST DVDRW GSA-S10N:
Firmware Revision: AP12
Interconnect: ATAPI
Burn Support: Yes (Apple Shipping Drive)
Cache: 2048 KB
Reads DVD: Yes
CD-Write: -R, -RW
DVD-Write: -R, -R DL, -RW, +R, +R DL, +RW
Write Strategies: CD-TAO, CD-SAO, CD-Raw, DVD-DAO
Five ways to eject a stuck CD or DVD from the optical drive
Ejecting the stuck disc can usually be done in one of the following ways:
1. Restart the computer and after the chime press and hold down the left mouse button until the disc ejects.
2. Press the Eject button on your keyboard.
3. Click on the Eject button in the menubar.
4. Press COMMAND-E.
5. If none of the above work try this: Open the Terminal application in your Utilities folder. At the prompt enter or paste the following:
/usr/bin/drutil eject
If this fails then try this:
Boot the computer into Single-user Mode. At the prompt enter the same command as used above. To restart the computer enter "reboot" at the prompt without quotes.
Regards,
Alex
The unit is fubar and needs to be replaced since repair is not cost effective.. You might open up unit to see if there is any debris in the path of the tray that could be interfering in its operation. If all is ok,time to go shopping.
there should be a small hole on the disk drive. with a paper clip push this in the hole and push. this should eject tray enough to pull it out the rest of the way.
If you look on the dvd drive there is a little round hole. Just get a paper clip and straighten it out and stick it into that hole. There is a little button that you push with the paper clip that is a manual eject button for cases like this.
