Canon EF 100-400mm f/4.5-5.6 IS USM Lens Logo
Mohammed Faizal Kakkat Posted on Dec 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon EF 100-400 not auto focusing
My Canon EF 100-400mm f/4.5-5.6 IS USM Lens is not auto focussing. only work with manual focussing. I use it with canon 60D
Paul Green
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Canon Expert 527 Answers
  • Posted on Sep 02, 2016
 Paul Green
Canon Expert
Level 2:
Prodigy:
Answers
527
Questions
Helped
232911
Points
686
It is probably a broken ribbon cable in the lens. It will need to be replaced.
3 Related Answers
Anonymous
  • 67 Answers
  • Posted on Dec 11, 2008
SOURCE: Canon EF-S 17-85MM F/4-5.6 IS USM prevents features from working on 40D
something sounds strange about this. aperture 00 is an invalid aperture value. stands to reason if that is the case the camera would complain about it. via error code. being that its only six mos. old i would give canon a ring.
Anonymous
  • 421 Answers
  • Posted on Jan 17, 2010
SOURCE: Canon EF 75-300mm f/4-5.6 III USM Lens
If your AF motor is hunting then the lens probably needs to be looked at. I wouldn't recommend this as something to do at home so you will need to either find a repair shop if it is out of warranty or return it to Canon if it is in warranty.
Anonymous
  • 6 Answers
  • Posted on Feb 06, 2011
SOURCE: MY CANON EF 100-400MM USM LENS WON'T ZOOM PAST
Is the lens tension adjusting ring too tight? Try loosening it and see if you get increased travel. If so, you may need to have it checked out.
My 100-400 mm EF canon takes too long to auto focus.I like to take pictures of flying birds and i get alot of blurred pictures even at a shutter speed of 1/3200sec. I use the #2 position on the stabilzer...
Manually pre-focus to the distance you'd expect then the auto focus won't have far to move/lock on. Only turn the IS off if you are using a tripod. The auto focus works by detecting a difference in contrast so if the conditions are not compatible i.e a BG the same as the subject it will 'hunt and peck'.
How do I adjust my Canon EF 100-400mm infinity setting on the lent. 300 to 400mm is out of focus.
I don't know your photography background and skill, so these tips may seem overly basic.
Have you tested this on a tripod? Not using a tripod can add a lot of blur, even while using the IS.
I would also try the lens at f/8 and see if you have the same focus issues. If not, it may just be related to shooting the lens wide open, where it's not the sharpest.
I hope this helps. It's just a few things to try.
Send a comment if you'd like some other possibilities.
Happy shooting with a great lens!
MY CANON EF 100-400MM USM LENS WON'T ZOOM PAST 150MM
Canon EF 70 -200mm F2.8L IS USM will not auto focus sometimes (using a 2x converter)
Check out the Canon guide for converters Some will not auto focus with a converter and you can only use manual focus
1helpful
18-55 lens not doing auto-focus
I offer you to buy Canon EF 24-105mm f/4 L IS USM Lens. This gives very good performance for your studio work and specially for portre. It has Image Stabilization and Ultrasonic Motor. Other professional lens are very expensive. It has red ring.
Please check the link below.
http://www.the-digital-picture.com/Reviews/Canon-EF-24-105mm-f-4-L-IS-USM-Lens-Review.aspx
Regards
Canon EF 75-300mm f/4-5.6 III USM Lens Auto focus motor keep working back and forth but lense is not able to stop on focus right. Had eror 01 also sometime with manual focus.
4helpful
Focus with polarizing filter
No, the problem is not with the lens. Your Canon camera requires unpolarized light to focus. Even on manual focus, you may have trouble seeing focus through the viewfinder. That's why they invented circular polarizer.
1helpful
Manual Focussing failure with Canon EF 100-400mm SLR zoom lens
I doubt if there is anything you can do yourself. The manual focus may have debris under the ring or is in need of parts. I would leave this one to a tech.
Jan 22, 2008 • Cameras
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
