I replaced the door latch on my MDW5600AWW & now the spray arms don't spray. I have cleaned the filter and everything accessible from in the tub checks out. I was wondering if I got the 4 wires going to the latch miss located would that have any effect on the wash cycle?
SOURCE: Poor wash performance - spray action not energetic enough
Same problem here! There's no obvious way to dissassemble, and on my model, MDB7100, I don't even have ability to clean the screens better than simply wiping them with my finger.
Am now considering strong cleansers, acids, and failing that, dynamite...
SOURCE: Maytag dishwasher filter keeps clogging
There is a product made to filter the water going into your dishwasher only to soften the water and remove the calcium before it enters your dishwasher. your dishes will be spotless and it will not get clogged again. you can get it at www.dishwasherfilter.com. it goes right under the sink and is very affordable. you will love this product and it will solve your problems.
SOURCE: dishwasher wont clean!!!!!!
The arms and wash are controlled by the pump pressure created by the impeller. It's possible that the impeller may be damaged. To inspect youll have to remove the wash arm, the gaurd and the pump cover. Ive included a parts break down.
http://www.partselect.com/ModelFrames.aspx?ModelID=272932&ModelNum=MDBH950AWS&mfgModelNum=&ManufactureID=1&Selected=54093&Position=2&mfg=Maytag&Type=&Mark=2
SOURCE: How to remove lower spray assembly in order to clean water filter
There should be a plastic nut holding the spray arm. Remove the plastic nut and the spray arm should release.
Does this help you?
Vic
SOURCE: Maytag MDB-4 Dishwasher Door Leaks and doesn't fit
Hi, t
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Hi If the top rack of the dishwasher
doesn't get clean, check your appliance to see if you can fix the problem. Then check to see if your
dishwasher has clogged filters. Filters generally cover the drain valve area to
catch debris as the water drains from the dishwasher. Many dishwashers have
maintenance-free filters, but your dishwasher may have filters that need
cleaning. Read your owner's manual before you perform any filter maintenance to
avoid damaging your dishwasher. Check your water temperature to
make sure it's hot enough. Water that is under 120 degrees Fahrenheit may not
be hot enough to clean dishes effectively. Turn your kitchen hot water tap on
and wait until the water warms up completely. Fill a cup and measure the water
temperature with a kitchen thermometer. If the water is less than 120 degrees
Fahrenheit, turn your water heater up to 120 degrees. Load the top rack properly. Place
cups and bowls upside down in the rack and don't nest dishes because this can
prevent water from reaching dishes. Don't overload the top rack. Instead,
position each item so the dirty areas of the dishes will receive full contact
with water spraying up from the main spray arm located beneath the top rack.
Prevent items from hanging below the top rack, which could prevent the spray
arm from rotating. Also check this link for more helpful
info:- http://www.ehow.com/info_7977311_top-dishwasher-not-getting-clean.html Please get back to us if you have
further query else please accept the suggestion.
First
check the spray Arms to make sure the holes in the spray arms are free and
clear of debris. Your dishwasher should have several spray arms, including one
at the bottom of the tub, one under the top rack, and possibly a third spray
arm on the top of the tub. Sometimes food and mineral deposits can block holes
in the spray arms, preventing water from spraying effectively. If this occurs,
warm some white vinegar and pour it into a spray bottle. Spray the holes with
the vinegar and dislodge debris with a toothpick or large safety pin.
Thank you for contacting fixya.com
