Michael Kors MK5060 Watch Logo
Michelle Colclazier Posted on Dec 18, 2012
Where can I buy this watch
I've searched everywhere for mk5060! Please help me where can I buy this watch?????:)
sharnika
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Dec 21, 2013
sharnika
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
424
Points
I can sell my Michael kors watch mk5060 email me
1 Related Answer
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Apr 03, 2011
SOURCE: hi i am trying to
Make, model, all numbers, please.
2017 Timex Ironman GPS watch. Where can I buy a replacement battery for it?
It's not that old, did you ask them direct? Servicing is their responsibility normally for at least 10 years. I can't find a battery with three wires either. The Garmin watches have a circular wired battery but only 2 wires.
Watch Repair Instructions & Guide
Timex https://www.timex.ca > watch-repair-instructions
Need help with watch repair for your Timex watch? Be sure to read through Timex's watch repair instructions and guide. ... Ironman GPS App.
Where and how can I sell a Michael Kors womens watch model MK5060
On E-bay. At the local market? Craigs list, Kijjiji.
Dec 21, 2013 • Watches
2helpful
I've been stupid enough to buy a fake Chinese
It probably has some cheap internals and as such you may be able to get them replaced/repaired cheaply. You should probably take it in to have it looked at at least. However, It is my opinion that you should just invest in a nicer watch. Or at least something you can rely on to function nicely. Even Walmart has ok looking watches that last reasonably well.
Sep 06, 2012 • Watches
I have a digital watch SHARP made that says SUNDAY when really it is TUESDAY how can i get watch to say the right day?
Take a look at your watch. While models and brands vary, you'll find a few things in common on almost all of them. First, they'll have different modes of operation. A typical digital watch may have modes for time, stopwatch, date, alarm and timer, to name a few. Look on your watch for a button labeled "mode." Press it several times to see what's available. Typically the watch will display the name of each mode as you push the button repeatedly. When you've found the mode you want to adjust, stop there.
  • 2 Look for a button that is labeled "set" or "adjust" on your watch. The location will vary, depending on the brand of watch you own. Press in and hold this button. After a few seconds, the time (or whatever mode) you have selected will begin to flash. In most cases, you'll need to select the item you want to adjust (minutes or hours) by pressing "mode" again. Once the portion you want is flashing, you're ready to adjust it.
  • 3 Press a button to advance the parameter (hours or minutes) that you've selected. This button may or may not be labeled. If it isn't labeled, you'll have to experiment with different buttons. Once you've set the first parameter, change to the second by pressing "mode." Follow the same routine to adjust. To exit, you'll typically press the "set" button.
  • 4 Use resources available to you. There are thousands of digital watch styles on the market, each with slightly different setting methods. When you buy a watch, tuck the manual away in a safe location for reference. If you don't have the manual, do a website search. Most major manufacturers keep their manuals online for easy future reference.
  • Jun 28, 2011 • Watches
    2answers
    I need to buy a new one, where to find it ?
    Try any local jewelry store, or a nearby mall. If you're unable to go to any of these places, you can always search online at stores like:
    http://www.amazon.com/
    http://www.ebay.com/
    http://www.buy.com/dept/jewelry-watches/64934.html
    http://www.google.com/search?source=ig&hl=en&rlz=1G1GGLQ_ENUS354&=&q=buy%20watches&aq=f&oq=#q=buy+watches&hl=en&rlz=1G1GGLQ_ENUS354&prmd=ivns&source=univ&tbm=shop&tbo=u&sa=X&ei=TrfBTaS6G8rYgQe09pDXBQ&ved=0CGgQrQQ&fp=9c234fa806b9df79&biw=1680&bih=892
    I hope that helped.
    May 04, 2011 • Watches
    2helpful
    4answers
    Cerruti watch strap cannot be changed in any watch specialists in middlesbrough and i am just wondering where i will be able to get it done
    You probably will have to send it away to get sorted (make sure you send it insured and very well protected).
    You should contact cerruti to see who the repair shop is in the UK, (not sure they have one.)
    Failing that you may be able to buy a replacement strap of ebay and have a general watch shop change strap for you.
    Or find a jewellers that sell straps, they should have one that fits.
    Please dont forget to vote if you liked my answer
    thanks
    Top Michael Kors Watches Experts
    NOEL
    NOEL
    ADMIN Andrew
    ADMIN Andrew
    deton8 von Splosion
    Are you a Michael Kors Watch Expert? Answer questions, earn points and help others
