SOURCE: One way comm only
swap batteries if does not work this unit should need repair or replace, display blinking can be produced for power failure ( battery, contacts, circuits) or can be a controller issue.
SOURCE: We tried using a headset with it. Now, without
Here is a link to the user guide, reference page 22 for instructions on turning iVOX and VOX on or off: http://www.giantintl.com/ContentManage/manuals/Moto/T65xx.pdf (Double check you do not have the lock symbol showing while trying to change programming.)
Also, another phenomenon which can occur is when you unplug a headset or audio device while the radio is still turned on. This can leave the radio partially in VOX mode. You might try plugging in the device with the radio turned off. Then turn the radio on, use the device in VOX mode. Then shut the radio off and remove the device. See if it clears the radio's sense of having a headset plugged in.
A damaged jack can also cause the same problem.
Best regards.
