SOURCE: Hobart lx18 Dishwasher wont fill up
Frank,does the sump probe (the one underneath the screen) look good?It should have at least one quarter inch of metal.I have seen these break and its hard to tell but the info your describing sounds like that probe is bad or the control board.I'm a hobart tech and can help you troubleshoot,let me know----Tony
SOURCE: Hobart Dishwasher Model #851017556
Hi The
rinse cycle will use around 2.27 liters (.59 gallons) of water and a
full cycle in the unit will consume about 15 liters (4 gallons) on average.
Hope this helps...please post back for
further assistance. Daniel
SOURCE: my lxi dishwasher drains more
There are two different styles of lxis one style has a drain diverter valve probably messed up some how something stuck in it not diverting the water to the wash arms and instead pumping right down the drain I am guessing this is your problem.There is actually a little black washer in the body it is controled by a dc solenoid .washer probably come off and is gone you will have to replace the whole drain body.This drain body is a real pain to change.Not easy but it can be done.If you change it yourself get the two new short hoses that go to it it will make things easier.But pull it out before you buy anything it could just be jammed.You can reach under the machine trough the front bottom plate where the gauge is located and move the flap by hand to see if it moves.TURN OFF ELECTRIC this little dc solenoid will give you a good zap.after doing that turn electric back on.leave cover off and look under with a fashlight.live wires will be exposed keep hands clear fill machine wait for it to stop.then turn it off it will drain when finished the solenoid will click three times.this is so drain will clear itself.if it moves then you have no electrical control issues.It is probably bad diverter valve.Good luck hope this helps.
