that's probably that your wallpaper isn't fit with your monitor resolution,for example,if your wallpaper size is 1280x1024 but your screen resolution (size) is 1024x768,it doesn't fit your screen and the wallpaper will only show half or even less to check your current resolution,click Start->Control Panel->click Appearance and Personalization->Click "adjust screen resolution" on the Display categories you can see your current resolution and also you can set your resolution To check the picture resolution,right click on the picture,select properties,click the Summary tab,and it doesn't show the resolution, click Advanced on the Summary tab But I suggest you to download the wallpaper with a fit size instead of changing the screen resolution,because too high resolution will make your screen goes black geez,i'm so sorry for my poor english please rate this solution if it's work and let me know if you still has a problem.and thanks for using Fixya!
If your memory card is 4GB or larger, AND if your computer is two or more years old, your computer's card reader might not be able to read the newer 4GB SDHC card. In that case, just purchase an inexpensive USB card reader from WMart, or Amazon (here's an example). Try a different card reader first to see if you can directly copy and paste the pictures from the card onto your hard drive. If the new card reader doesn't see the files, then try recovery software. Here's some freeware to try. If the software still doesn't see the card with the new card reader, you may next need to try the corrupted card procedures described at the bottom of this linked article.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
the recharge kit will only fit on the low side fitting which is the smaller fitting on the larger lines/hoses. If it doesn't fit on the fitting you have tried than you are probably trying to put it on the high side fitting which is the larger fitting on the smaller lines/hoses. I think the low side fitting is on the receiver drier on this model which is the canister looking thing back by the passenger side of the firewall.
You cannot put a memory module in the wrong way. It won't fit. If you actually got it in, you have probably broken something--either the module itself or the motherboard.
Hello and Welcome to FixYa!
Yes, it has been seed that other similar model cables doesn't work properly due to minor changes in their structure, although he connectors are same but I'll recommend you to get the original cable for your cam.
The inappropriate cable may end up in some other loss.
I hope you understand.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed. Concerned, Nooh: FixYa Team.
