Motorola Mobility RAZR V3 Logo
Jade Taylor Posted on Jun 14, 2007
Razr V3 i have no signal atall on my razr v3 everytime i load it up no damage done to it atall no water tried takin battery out cleanin etc but it still wont work
  • Renee Thornsberry Feb 01, 2009
    My razr v3 gets signal then drops the signal over and over. How can I get the service to stay I have ATT.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jul 03, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
195
Points
Do u have ur sim card in? do u have service where u are? go to settings>network>new network see if itll work
Verizon Razr V3 with locked screen. Verizon
yes ,down load p2k or another flashing utility,then flash your phone
2answers
Motorola razr v3 not catching signal
Have you used the external antenna port? If this is damaged it renders phone useless. Somehow connected to main antenna.
RAZR V3
change your signal recever by giving it in a service center
Razr V3 won't power up anymore
try a new battery and also clean the charging port if after the battery and still nothing then you need to take the phone and have it tested.
Razr v3
what you can do is go to your manual and correct it....
Razr V3 - Outbound Calls fail
sounds like a signal problem check the bars of signal on your phn might be the antena try placeing your sim into one of the other razers and see if call goes through and let your service provider know they can send all info to phn like a new activation might be a issue where you cant connect to a tower if thats the case youll need to talk to your service providers tech department and have them check for the lrn easy way to see call your phn and see if you get dead air or fast busy signal
2answers
Motorola RAZR V3 Cellular Problems With Water Damage
yes it is bad
getting hot means that the internals are frying or shorting out
leave the battery off of it for about a week then try it again.
I really don't like your chances of it working properly again though.
Good Luck
Razr v3 dead battery
you have a dead battery, this happens often. all you can do is just buy one, ebay
3helpful
5answers
Motorola RAZR V3 No signal (bars)
I had the same problem with my phone- i got a cheap generic battery to replace the old one (which wasn't holding a charge for a full day, at that) and then i lost all signal, basically. I tried what scm_pa said he did - charged my old battery up, with the phone off, till the charge was complete- turned the phone on, and voila, reception!
Motorola RAZR V3
the mainboard is gone and have to either be replaced or taken to a mobile service center close to you and hvae them use special equipment to revive it.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
