Question about Kia Vehicle Parts & Accessories
Rpm fluctuate in 04 kia sadona
What is the sensor unit called
  • Kia Master
  • 694 Answers
Throttle position sensor
Posted on Mar 02, 2014
SOURCE:
What is the wiring harness on my 2005 kia Sadona hood latch mounting bracket
If you are talking about the sensor on the lower part of the brace. It is Probally an impact sensor Or a sensor to monitor the outside air temperature. Let me know if this is not what you are talking about.
Jan 03, 2017 | 2005 Kia Sedona
I have a 2007 Kia sadona and I am look to see were the crankshaft sensor is?
Most of those sensors are located next to harmonic balancer in the timing cover housing. There is a reluctor wheel on the front of the cranshaft built into the harmonic balancer. It also might be located inside the cover too but near the front of the crankshaft. Does the vehicle have no spark? The sensor helps with the correlation to time the engine for spark.
Oct 13, 2015 | Kia Cars & Trucks
Where is the knock sensor on 2003 kia sadona?
You don't say which engine you have but the knock sensor is usually into the side of the block(may look like the oil pressure switch) or into the head casting. Go on "images" and that will help you recognise it.
Mar 30, 2015 | 2003 Kia Sedona
What would cause my engine to knock after changing plugs and wires on my 04 kia sadona
you might use the wrong spark plugs or mixed up the firing order.does it miss when you excelerate?
May 05, 2014 | Cars & Trucks
While driving and holding steady speed, the rpm's fluctuate 200-300 rpm's
How many miles are on this vehicle? Is the engine light on? If so, can you have the codes read? RPM fluctuation can be anything (both caused by mechanical or electrical changes or failure/s). Fuel pressure, engine compression, 02 sensors, worn or sticking TAC unit, vacuum leak, poor fuel quality, dirty or defective MAF sensor, clogged air filter, old spark plugs, excessive exhaust back pressure, stretched timing chain, over due oil change, worn or damaged throttle pedal, or worn out spark plugs. These can all cause your symptoms. Let me know if you have anymore questions.
Feb 16, 2014 | 2005 GMC Envoy Xl
The engine rpm's fluctuate both while driving or
just happened to my 05 Kia Optima. It needed a new coil pack.
Jul 23, 2011 | 2005 Kia Optima
How to change transmission fluid and filter in my 2003 kia sadona
ITS VERY MESSY UNLESS YOU HAVE A BIG PAN TO CATCH ALL THE TRANNY FLUID, BRING IT TO A TRANNY SHOP INSTEAD, PAY SOMEWHERE FROM $75 TO $100
Jul 24, 2010 | 2003 Kia Sedona
The rear wiper on my 04 Kia sadona won't work. The fluid still comes out,but the wiper itself will not move. Checked the fuse and it's good. Now what?
turn it on go feel the wiper. the gear that moves it mite have stripped. or the threads on the wiper arm. you should feel if its moving if not you need 2 change the wiper motor
Feb 13, 2010 | Kia Sedona Cars & Trucks
2005 kia sadona belt replacemnet
This guide will help you. Just provide an email and log on.
http://www.kiatechinfo.com/
Jul 15, 2009 | 2003 Kia Sedona
Vehicle Parts & Accessories Logo
54 people viewed this question
Top Kia Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Cameron Lewis
Cameron Lewis
Level 1 Expert
Kardoc
Are you a Kia Vehicle Part and Accessory Expert? Answer questions, earn points and help others
