Question about GE Rf-modulator 73452 Connects All Kit
My RF-modulator works when I use a short coaxial cable but will not work on longer runs. Why?
I tested the RF-modulator hook up on a short run from my dish reciever to a small tv via a short (3') long piece of coaxial and it worked. When I tried to extend the cable into the other room, I could not get an image.
    Top Expert:
  • GE Master
  • 52,821 Answers
RF modulators are intended for short runs. There is too much signal loss for a long run
Posted on Dec 17, 2012
SOURCE:
My wii u stil wont work after being hooked to an rf modulator to an older tv
Hi Lisa can you provide some more information
What is the model number and make of the rf modulator?
what wii output did you use to go into the rf modulator ?
what frequency does the rf modulator output at ?
What model number and make is the television ?
What type of cable is being used from the rf modulator to the tv ?
Is it a video cable or a proper 75 ohm impedance coaxial cable
what is the impedance of the rf modulator output is it 75 omhs and what is the impedance of the tv is it 75 ohms or is it 300 ohms if it is 300 ohms on the television ( usually antenna is a ribbon cable screwed onto the back of the tv rather than a coaxial socket ) different you need a balun
http://www.jaycar.com.au/productView.asp?ID=LT3022
I am recommending your first point of problem trouble shooting first is to check the impedance of your television compared to the impedance of the rf modulator and compared to the impedance of the cable used. IF they do not match then power is lost and the signal won't get to the TV.
Dec 27, 2014 | Nintendo Wii U
How do i connect my lg42lh2000 to my lg ht302 receiver so that the sound from the tv can be heard through the recivers speekers
you will need:
rf modulator.
coax cable.
video cables.
run audio cables from yourmusic source to the reciever that should work but if your music source is away from the reciever then get an rf modulator and put your music source by your reciever and the put thevideo cable from your music source to the rf modulator and tthenrun a coax cable to the tv and then run the audio cables from the music source to the input on the reciever. for example i have my direct tv box sound running through my reciever and speakers, and to have musicfrom the direct tv box going through my speakers i put the audio cables from my direct tv box into the audio input on the reciever and then the video cable into the rf modulator and then from the rf modulator i ran a coax cable to my tv then i had my sound from the direct tv box going through my reciever and the video on the tv.
plz tell me if this works :)\
Aug 05, 2013 | Audio Players & Recorders
Can't find where to connect for dvd. no white,yellow,or red plug.
Hello, Thank you for the opportunity to help
Sounds like you got a pretty old tv there, its frustrating not to see the RED/WHT/YELLOW plugs on it. This is because this tv was made when that was not out yet. So are you out of luck? No, you ar in luck but it will cost you a little money.
You can purchase one of these RF modulators at Radio shack for like $29.95.
OR
If you have a VCR, Generally they have these plugs out the back of them you would plug the DVD into the VCR in the Video IN. You're TV will need to be on channel 3 or 4 (dending on your vcr) You vcr will need to be powered ON then tuned to VIDEO INPUT. You can do this by using the remote's up/Down channels buttons or pressing input on the remote depending on the VCR.
The VCR will need to be connected to the TV's coaxe port on the back, That port looks like this:
If you do not have a VCR you would purchase a RF modulator you TV will need to be on channel 3! The modulator is connect to the port pictured above above. The DVD is then introduced to the ports on the back of the modulator witch looks like this:
rulds2008_40.jpg WE hope you found this Very Helpful. This was answered by a human being, That works hard answering FREE questions just for a Thank You!
Regards,
Rulds2008 "ED"
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jan 27, 2011 | Zenith Z19A11S TV
I am trying to hook up my Philips 19PR19 (made in 1998) tv to the dish network receiver, it has 3 prongs diff. colors attached and the cable cord is already to go in the wall...I don't see anywhere on the...
Because your TV is an older one, it might not have, what they call RCA inputs (the 3 colored cable) Red-audio right, White-audio left, Yellow-video. If I understand you.
You do have the option of using the 75-ohm coaxial cable inputs. Signal comes in from outside to the 722k, Output of the 722k to the 75ohm coax input on the back of the TV. Tune your TV to ch. 3 or 4. Make sure the switch on the back of the 722k is set to the same.
If you really want to use the RCA colored cables, then you need to buy an RF modulator, which integrates older tv's to newer products. But usually dvd players, not necessarily cable boxes, but it would work if hooked up correctly.
You plug the RCA red, white and yellow from the 722k, into the rf modulator, choose channel 3 or 4 on the modulator
Connect 75ohm coax cable from rf modulator to TV 75ohm coax cable input. Choose channel 3 or 4 on the TV.
Hope this helps.
Apr 07, 2010 | Philips 19PR19 19" TV
Have an RCA F27636BC TV. Can u hook a DVD player
How to hookup TV
If you have a TV with only a single coax input and you want to hook up components like DVD players and VCRs, here's how to do it.
What you need to connect your DVD player or game players to a TV that only has a VHF/UHF 75-ohm F-connector ("coax antenna input").
1.) RF Modulator with Stereo Audio Inputs.
2.) 6 foot long coaxial cable with male "F" connectors. This cable goes from the modulator to the TV. The modulator also has a coaxial input to plug in your antenna or your VCR.
3.) 6 foot long Video and Audio Cables with "RCA" plugs. The cables connect the yellow, red and white outputs from your DVD or game player to the yellow, red and white inputs of the modulator.
Works with X-Box, PlayStation, Nintendo or other devices that output audio/video via the RCA plugs and you want to connect them to your coaxial only TV.
Nov 24, 2009 | RCA F27636BC 27" TV
How do you hook up the dvd player to the tv with a vcr hooked up to the tv
Leave the cable box powered on but disconnected from the TV or VCR. All other components should be disconnected and unplugged, giving clear and easy access to all connections. If components sit in an entertainment unit, make sure all A/V cables can reach the RF modulator and the cable from the modulator can easily reach the television.
  • Step 2 Hookup the first coaxial cable from cable box output, usually labeled "TV," "TV out" or "Out to TV" to the cable "In" on the VCR. Connect the second coaxial cable from the VCR's out to "TV" to the coaxial input on the RF Modulator.
  • Step 3 Connect the third coax cable from the coaxial cable "Out" jack on the RF Modulator to the coax cable "Input" on the television.
  • Step 4 Take one A/V cable, connect the red (right audio channel,) white (left audio channel) and yellow (video) from DVD player's "Output," to the corresponding DVD "inputs" on the RF Modulator. Place components as desired but still disconnected from power. Plug in all power cables including the RF Modulator's into the surge protected outlet strip.
  • Step 5 Make sure the Channel select switch usually found on the back of the VCR and the Channel select switch on the RF Modulator are both set to Channel 3. This channel is used on the television to view your components.
  • Step 6 Turn on the power strip and turn on the TV. Cable reception should come on as usual. Set the TV to Channel 3 and turn on the VCR. With VCR on test it by playing a video tape. The RF Modulator should sense the signal and automatically switch to "VCR."
  • Step 7 Switch off the VCR and with the television still on channel 3, turn on the DVD player. As the RF Modulator senses the DVD player signal and switches to DVD, its welcome screen should be seen on the television. Play a DVD to test and once you're done with the DVD turn it off and the cable should come back on.
  • Jul 15, 2009 | Televison & Video
    Connect magnavox dvd to ge tv HELP!
    You need to go get an RF modulator. They can be purchased at Radio Shack or a number of other electronic shoppes for a reasonable price.
    The RF modulator connects to the coax cable connector and it has inputs for the RCA connectors.
    Cheers ... Best wishes
    Jan 30, 2009 | Televison & Video
    Connecting a samsung dvd-vr to TV with cable & rf modulator
    my coaxial cable hook up is broken from the plasma. Can i fix it?
    Jun 15, 2008 | Samsung LN-R328W 32 in. HD-Ready LCD...
    Need directions to install a dch70 box to tv
    dear woolifer ,
    I am not an expert but i hope i can help you..
    is it youmean digital cablebox?
    if it is try this-
    This is a problem a lot of people have with coaxial-only televisions because DVD players do not have coaxial (RF) outputs, which means they can't be connected directly into a television with only a coaxial (RF) input. The solution is to purchase a RF modulator, which is a small device that will convert the AV output from the DVD player to coaxial (RF).
    As for the instructions, I am going to assume the DVD player is not a combo unit with the VCR, and that you want to record TV on your VCR. Step 4 will include connecting your DVD player, but if the DVD player is a combo unit with the VCR, just ignore step 4 part as DVD connection will be included in the VCR set up. Actually, you wouldn't need the RF modulator if it is a VCD/DVD combo unit.
    1. Connect the coaxial cable coming out from the wall to your digital cable box in the ‘video in’ slot. It might also be labeled ‘antenna in’ or ‘cable in’.
    2. From the cable box, connect a coaxial or composite (yellow video cable) and stereo (red-white) RCA audio cables to the VIDEO IN terminal on your VCR.
    3. From the VCR, you will have to connect this to the RF Modulator using a coaxial cable from the VIDEO OUT on the VCR to one of the IN ports on your RF modulator.
    4. You can now connect your DVD player to the RF Modulator by using the yellow-red-white composite/RCA cables from the VIDEO OUT on the DVD player to another port on the RF modulator.
    5. From the RF modulator, connect this unit to your TV by using a coaxial cable. It will be from the VIDEO OUT on the RF modulator to the VIDEO IN or CABLE or ANTENNA IN port on your television.
    This should be all you need to get started watching your digital television. In simple terms here is what you did:
    Coaxial from wall to cable box
    Cable box to VCR
    VCR to RF modulator
    DVD player to RF Modulator
    RF modulator to TV
    You will only be able to record what is on channel
    Apr 09, 2008 | Computers & Internet
    No display
    Press the DVD button on the Philips remote. Make sure the yellow part of the RCA cable is plugged into Output/CVBS/Out on the back of the Philips, and that it is plugged into a yellow input of your TV. Change your TV channel to Av1, av2, video 1, video 2, aux, aux 2, or whatever the correct video channel is on your TV. Then press setup - you will get your picture.
    In order for the coax connection to work on Ch. 3 of your TV, you will have to get an additional piece of equipment - an RF modulator. It's better just to stick with the RCA red, yellow, white cables.
    Sep 02, 2007 | Philips DVDR3455H/37B
    GE Rf-modulator 73452 Connects All Kit Logo
    82 people viewed this question
    Top GE Televison & Video Experts
    matt martin
    matt martin
    Are you a GE Televison and Video Expert? Answer questions, earn points and help others
