My laptop was changed from its Vista format to XP without my permission and I want to get it back. I'm also getting a lot of popups from Microsoft claiming I'm operating under a fake copy of their system. I have a genuine copy but I'm getting nowhere with them. So, I think the only solution is to save all my files, or copy them to disks and do a factory reset. Will my computer allow this and be fully restored to its original state? Thank you.
You can definitely do that. Backup your files and then follow these steps:
1. Power on the computer.
2. Hold the <CTRL> key and press the F10 key until the Recovery Menu appears
3. Select 'Restore'
4. Select the setting to restore the system to the Factory Image
5. Walk through the remaining prompts to complete the restore.
SOURCE: acer 3680 factory reset
here is the link to the manual for your laptop. please go there and take note of pages 70-73 that show how to restore your system with and without the disks.
SOURCE: How do you change the password on a Aspire 43`5
Ok.. Seems like its the HDD password set using the BIOS. You can remove this pasword by taking out the CMOS battery for about a minute. This would reset all of your BIOS settings to default there by clearing the password. For more information click here
SOURCE: Downgrade from Vista to WinXP Pro
No, you need to go into your computer's BIOS and set the ahcp mode to IDE. Then windows xp will see it just fine.
Please take a moment to rate as fixya. Thanks!
SOURCE: Acer Aspire 5100 won't system restore
If you created your system restore CDs when you purchased the system, insert your first CD into the CD drive and boot your computer. This will restore your computer to factory settings. ALL DATA WILL BE LOST.
SOURCE: restore factory settings
there are 2 ways for doing this
1) Fast and easy without backup disk just do this
Acer: When you turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
2) If the method above doesnt work u can do it thru backup disk u have got when u purchased ur laptop u shud have made it thru Erecovery software.
Pls rate me FIXYA for help !
You have to be the computers administrator to change any values on any hard drive on your computer
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
click start click on my computer you should see your usb drive
right click then select format
another way is to control panel administrative tools computer management disk management right click on your drive select format
hope this helps
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control click start control panel user accounts on the users tab click the name of the computer administrator you must have full control click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 If you are running a Windows XP OS then you might be able to: hope this helps
you have to be the computers administrator to change any values on any computer hardware
and you must fall full control of your hard drives
Right click the icon of your Flash Drive (It should be F:/ or something)
Click permissions
