I put the bike on charged the light is green can here throttle like it wants to go but it does nothing can someone please help me with finding the problem
Yes!your battery needs replacement.....throttle clicking after a full charge is a sign,...but that's after 2years or more,depending on how it's being used..your motor can go bad before then if you been riding in the rain--wet connectors in or out the motor can not get wet for any reason..a full dirt motor bike can not get full dirty with mud..mud catains water/water and electricity don't mix/////.motor/thottle/moisture.
SOURCE: My boys have not rode
The battery went bad inside the bike. I would take it out and go to batterys plus and they will help you pick out a new one
SOURCE: Indicator light fully charged...but barely enough power to move
Clean and tighten all wires connected to the battery, motor , controller etc.being doubly sure of all grounding wires . Don't take any shortcuts ...remove wires ,clean and inspect for cracking or burning, clean and or replace....this will pay off for you...Good Luck....Tim
SOURCE: I was given a mx350
If it was working before it sat, then it is almost certainly the battery (these kinds of batteries suffer if sitting and not fully charged). If you had one, or could borrow a voltmeter, you could check the batt. Also, lots of car part places like NAPA can test batteries for you.
Hope that helps
