Question about Epson AcuLaser C4100 Printer
Aculaser C2600 "clean sensor" message won't clear. Have just replaced K toner and it printed about 300 copies then stopped with the message. opened cover and closed it but after calibrating the message comes back on. A while back I replaced the Photoconductor unit. That's done about 2500 copies. Any ideas?
  • Erich Buxbaum Mar 06, 2009
    Changed cyan and now I get "sensor cleaning" and cleaning all parts did not help yet.
  • Anonymous Apr 10, 2009
    Exactly the same problem but on the C1100n printer.
This is a common characteristic which arises from using improperly remanufactured toner cartridges.
Otherwise it is a bad Epson original one - which is highly unusual!
When the C2600 runs through its calibration it prints strips of each colour on the transfer belt which are sensed for density. You will get a "clean sensor message" if the reading for any of the strips drops below a certain value.
The first thing to do is to depress the clean sensor lever behind the front cover several times . If that doesn't fix it I would advise you to remove each cartridge in turn (go to reset menu and scroll down to change toner) and inspect the toner on the surface of the roller. If there is any form of "sheen" then you'll need to replace the cartridge.
It is possible to adjust the doctor blade if you know what you're doing but be careful as there are shims on each side. Loosening and moving the blade bar towards the roller slightly, refixing and then turning the side cog to rotate the roller can sometimes resolve problem. Not a good idea really unless you're in an emergency.
There are some good remanufactured cartridges and bad ones. If you want to avoid this buy genuine Epson cartridges - I know they're expensive but what does the down time cost!
Posted on Jun 19, 2009
I had the same problem, the message was in dutch (epson aculaser c2600 'sensor reinigen'). First I ordered a new photoconductor, but that didn't solve the problem. After checking each tonercartdridge I found out that the Yellow was too poor (stripes) on the surface of the roller. I've put in a new one and the problem was solved! But the old yellow unit was 75% fill. And I always use original Epson replacements...so I think this was a wrong manufactured toner...hope this info can help anyone.
Posted on Aug 31, 2010
This happened to me as a result of keeping the cartridges that came with the printer and buying powder refills. After the refill the print was ok for the test sheet, but then I kept having the issue. I tried for about 1 hour opening the front panel and closing it to initiate the "clean sensor". I then turned it off for about 2 hours and tried again, after about the 3rd "clean sensor" routine I managed to print the test page and I have run a few other pages through since then. So keep trying to "clean sensor" quite a lot, that worked for me.
Posted on Jan 30, 2010
    New Friend:
My last effective solution was removing all toners and cleaning them by blowing the surface around the toner cilinder and .. it worked!!!
Posted on Nov 20, 2013
Hi, I got the same problem on my epson c2600.
After I replace the new photoconductor and also replace the waste toner collector .... the printer can be used again. But after printing approx 20 pages, CleanSensor message is displayed again... :(
Please advice
Posted on Jun 07, 2011
SOURCE:
My bizhub c25 waste toner was full so replaced and will not now reset.
The C25 stores toner in a waste toner container. On the front of that container there is rectangular clear window that fits into a sensor when installed into machine. The sensor passes a beam of light through that window. When the bottle is full there is toner inside that clear plastic window which stops the light from making it through the window and the machine will tell you the waste toner is full. Just dumping the container out will not clear that window and by putting it back in the machine you will get the same toner full message. If you are going to try to reuse that container you will have remove the black plastic cover that is glued to the container above the clear plastic. Then use something like a Qtip to clean all the toner off of that clear window(much easier and faster to just replace in with a new container). if you still get the waste toner full message after you install it then remove it and wipe off the sensor that the clear window sits in. This will clear the message and you can continue your copy job.
Apr 02, 2014 | Konica Minolta Office Equipment & Supplies
Error e527 have manually removed all cartridges and replaced them and the PCU but the error code persists
Error E527: home position sensor error
Solution:
  1. open the left cover
  2. remove the home position sensor
  3. clean it ( remove the toner)
the home position sensor is shown at this picture: mabroukmedal_32.jpg
Dec 09, 2010 | Epson Aculaser C1100 Printer
Epson aculaser c2600 error e114
This means the transfer unit has reached end of life and should be replaced.
To reset the message you must enter in a maintenance mode
Press back+up+down+enter and switch on the power.
In the maintenance mode Scroll trough to "Reset Tr counter"
Oct 15, 2010 | Epson AcuLaser 2600N Printer
Epson Aculaser C2600 Service code E144
This is a Transfer Belt Error - "Worn Out".
This is not a consumable item. Have had to contact Epson direct who have arranged for a service engineer to replace the offending item.
Nov 12, 2009 | Epson AcuLaser C2600N Printer
Epson Aculaser C1100 erro message install C tnrcart
You need to remove the cyan cartridge, and thoroughly clean the inside of the printer (please use proper printer cleaning kit, not a damp cloth!). The sensors can get crudded up with loose toner inside the machine.
Oct 28, 2008 | Epson Aculaser C1100 Printer
ACULASER CX11NF Photoconductor reset - chip?
The reset chip will not provide you with a long term solution to your problem. The photoconductor unit is now full of waste toner and the photoconductive drum, prime charge roller and wiper blade are all worn, this is the cause of the message. Your only real and the correct solution is to replace the Photoconductor unit with a new one. Remember that this is part of the consumable set for this printer and is therefor costed in as part of the cost per page.
Should you proceed with the replacement chip, you will be opening yourself to deminishing quality print and eventual failure of the unit.
Gremlin11
Jul 24, 2008 | Epson ACULASER CX11NF All-In-One Printer
Black Cartridge just changed, but still says K-toner low
The only way to clear the message is to wait until the the display shows XXXX Toner Out, then change the cartridge and the message will clear itself.
May 18, 2008 | Epson AcuLaser C4000 Printer
Epson Aculaser C9100 Colour Laser printer
If you changed the bottle and rebooted the printer with no change, it could be that the sensor for the bottle may be faulty. Try cleaning it:
1. Remove the CASSETTE ASSY.
2. Open the COVER ASSY FRONT.
3. Remove the two screws (silver, flanged, 8mm) that secure the COVER over the sensors. Remove the Snap from the main unit Frame, and remove the sensor COVER.
4. Use a paper towel or cloth to clean the sensor area of any dust or toner
Nov 08, 2007 | Epson Aculaser C1100 Printer
Epson AcuLaser C4100 Printer Logo
8,961 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
