Nesesito codigo de seguridad porke se me olbido
SOURCE: MI LG ME PIDE UN
Hola!
Si has olvidado el c?digo de tu LG serie VX puedes intentar lo siguiente:
1- Ingresar *22899
(asterisco22899)
2- Esperar a que tu tel?fono se "reprograme".
3- Una vez completado el proceso, deber?as poder desbloquearlo utilizando
los ?LTIMOS CUATRO D?GITOS DE TU N?MERO DE TEL?FONO.
Espero haber podido ayudarte. Saludos!
SOURCE: CODIGO DE AUDIO PARA LG C300
If you are using HDMI for sound, and are not too concerned at losing 5.1 surround, in the PS3 sound settings set Audio Output to Optical ... set all options and save, and then set MultiOutput to On which will allow audio to pass back through HDMI even though Optical is default, albeit the audio will be two channel. This will work (I had the same problem). Still working on the surround sound issue ... without working on the various re-encode options floating around the net.
SOURCE: necesito el codigo para una tv LG
Check this site. For more details type in this site name "Electro-help" to search box [not
in the address bar of your browser], and click search or press
Enter. It is an electronic equipments
service help site.
Note the
position of hyphen in between words in site name. The site will appear as it is in
web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts.
You can locate this site
name, either at the bottom part of first search page, or at the top of second
page. Detailed
descriptions are there to help you. Sometimes,
clicking on advertisements by the side and bottom of each post might help you
to get details about the availability of spare parts; price and more.
