I have a 46" Sharp Aquas LCD with HDMI inputs, however, I cannot get a signal from the Cox converter box although the HDMI cable is connected. I can get the signal through the componet cables and off the antenna. I have used two separate HDMI cables and neither work. Contacted cox tech and they said it should.
When I scroll through the inputs on the TV, it will not go to the HDMI inputs -
Am I missing something in the settings or does this indicate a faulty TV?
Loye
When the tv won't scroll to the HDMI inputs, it means that the tv does not detect a signal on those inputs. This either means the tv has an issue and can't receive an HDMI signal(very unlikely) or there is no signal being sent from the source(converter box) The first thing I would do is unplug all output connections from the box except for the HDMI output and see if this gets rid of your problem. If not, I would be more inclined to think you have a problem with your converter box than with your TV. You could also try using the HDMI ouput of a DVD player if you have one.
