This copier was working perfectly. Next day someone did something in the lobby and the next time I tried to use it by feeding papers into the ADF it did not give that familiar "beep, beep, beep"? How do I check & repair the ADF.
SOURCE: hp psc 1315 paper jam
. Switch off the
printer and disconnect the power supply. Allow any residual charge
inside the all-in-one printer to dissipate before putting your hands or
any metal tools inside the chassis.
2. Pin down the exact
location of the jam. The 3 hot spots for a jam are before a sheet
completely leaves the paper tray, anywhere between the feed tray and
print carriage or between the print carriage and output tray.
3. Take off the front
paper tray if the sheet jammed while still in the front area of the
printer. If here, you should be able to see most of the paper.
4. Pull the sheet with
both hands and steady pressure. Do not tug as you might rip the paper,
leaving a piece deeper inside the machine.
5. Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6. Use the carriage
access door to get at a jam further inside the printer. You may need to
remove the print carriage to get to the jam.
7. Replace all parts and
return any access panels to their closed and locked positions. Plug
your printer back in and flip the power switch.
SOURCE: Lexmark x4270 wont feed paper
In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... It should resolve the Issue......... Good Luck..........
SOURCE: HP LaserJet 1300 Printer.
feed the paper in the tray then push the button next to the orange light should fix it hope this helps regards Jim
SOURCE: can't clear ADF paper jam--I
CHECK INSIDE FOR PAPER AND RESETBY CUTTING MPOFF AND RESTARTING .SOUNDS LIKE A SMALL AMOUNT IS INSIDE SOMEWHERE.. GOODLUCK
SOURCE: My Epson px800fw is claiming that there is an ADF
Make sure that the paper has no staple wires, punched holes or not crumpled.
Testimonial: "Thank you for the advice. The fault is hardware based as the problem occurs in copy mode - no computer involved. "
