SOURCE: K3367 one pice toilet harmonic vibration
check your water preasure. it sounds like it's to high and you should adjust your prv
SOURCE: I have 2 K3466 model Kohler toilets and just had a
There is a volume control screw on the valves usually a plastic thumbscrew on side of valve turn clockwise until they quiet up the plumber should have adjusted that these are very tempermental toilets but when adjusted properly are excellent toilets I have 2 in my own home
SOURCE: Hi, I have a Kohler toilet
Go to the Kohler web page and try to find your toilet. The numbers you have here are not jiving. They have pictures of all models. Once you get the Kohler Mdl. number, you should be able to obtain info on which fill valve you need. Most of the parts are not that hard to purchase.
http://www.us.kohler.com/onlinecatalog/category.jsp?section=2&nsection=2&nsubsection=3&category=13&nitem=cat13&brand=kpast&source=google&mat=exact&cat=branded&kwd=kohler+toilets
