As I went to turn on my dishwasher, I notice that the clean button stay on. Normally I would just press the cancel button and everything goes back to normal . But this time I can't remove this clean flashing light.So this mean I can' t even start a new load of dirty dishes. Can you please help me determine whats wrong. Thank you
If clean light is on, it usually means it ran ou of hot water before it finished the cycle and does not consider the dishes clean. To heset you must hit these buttons in this sequence. Heated dry; normal wash;heated dry; normal wash; heated dry; normal wash; (All lights should light up) hit cancel
Although the light may be a true indication of a pending problem, try this test: Find the circuit breaker and switch it off to remove power to washer for 30 minutes. Then power back up. Any changes? If light still on, then threat of trouble is real and must be fixed. Not sure what to CLEAN, though. Search for manual online...I'm sure Kenmore put that light on for a real purpose.
Clean light keep flashing, and manual indicated drying heater has problem? Any idea how to disconnect or if heater coil defective?
