Assuming the pedal itself was put together correctly, check lead dress and see if there may be any stray metal bits shorting traces, and then look at the power supply. Try a different supply and see if the pedal works. If pedal does not, and the supply you are trying is good, look for wiring that may be incorrect or broken from when you opened it up. You may need a meter to make sure polarities are correct if you removed any wires from their connections. Also look at the possibility the movement of your inspection may have been enough to make a marginal solder connection fail totally. It happens, the RoHS compliant solders do not wet leads as well as the old lead/tin solders did. Just reflow the solder joints.
But, the power supply is a good candidate for a failed electrolytic capacitor. The offending caps may be bulged or leaking.
Thank you so much for the information. I left it on for a minute or so after the leds blinked and then shut off and then 7 leds light up and stay that way. I do not know what that means. The caps in the power supply section look fine. No leaks or buldges. Also There is one light that remains on once the unit appears to shut off. This led is only visible when the mother board is free from the casing. Any clue as to what that might be all about? Thank you!!!!
SOURCE: The correct order for Effects pedals.
Input guitar into the tuner then whammy type effects last into distortion effects then to the amp input.
SOURCE: my alesis sr-16 won't power
Likely the input rectifier and filter in the SR16 has shorted diodes or caps. Should be easy fix for a competent electronics tech.
