It sounds like it's not configured to be a DHCP server. It should be a setting you can turn on. Login to the router. You may need to manually set your computer's IP to be in the same subnet as the router so that you can do so. The default address for the Netgear 7550 would be
http://192.168.254.254, so you'll have to set your computer's IP to something like 192.168.254.253, and then browse to the above address. Username and password are both "admin". If that IP doesn't work, try setting your computer's IP to 192.168.1.2, and browse to http://192.168.1.1, then look for a "DHCP Server" setting in the Local Area Network section, and make sure it's checked.
