When I plug it it with the USB it charges but it wont let me put songs on it and it's saying my computer cannot recongnise it! Help please!
SOURCE: ARCHOS 404.. new.. won't turn on or charge
Leave it to charge for 2 hours just in case there isn't enough power for it to boot up properly until it has an initial charge.
SOURCE: Archos 504 160gb wont start
Take the battery off, and to the left of the battery connetion tabs is a small gold button, push and hold for 10 seconds. It should start up after doing this.
SOURCE: first time charging up of archos 5.just the green
Your archos probably has a glitch in it. You might have to do a system recovery of it. First download the latest firmware program from Archos website. Here is a quick possible fix when the screen comes up reset the archos by inserting a paperclip in the reset hole located at the bottom of the unit right of the connectors it might work it might not. if that doesn't fix the problem do a hard reset when the logo screen comes up hold down the volume+ button until the white recovery page comes up. First try repairing the unit if that doesn't work try format and follow the instructions. the touch screen doesn't function during the recovery page so use the volume+&- buttons & power button. When you get done your archos should be set to factory presets so you have to set it up. Good Luck
SOURCE: My archos wont connect to my computer
i had this problem. you have to use a high speed usb port (2.0 i think) which is normally in the back of your computer and then it should be detected
SOURCE: Archos won't connect by USB to computers
You should keep your eye on the device after its been plugged to the PC it will give you 2 options "charge" or "usb" you ca not establish a connection without picking usb connection option on the Archos screen when it pops up. If you are doing so and problem still existed then i would recommend you to download the latest windows media player. Because it comes with new devices sync driver update.
