My dryer is a sears kenmore elite model number 110.64972200 People are saying its my heating element but it has no problem getting hot just wont dry clothes in a timely matter. I put in two towels and it took three hours to dry them
If the drum gets hot to a real degree it has to be a blockage between the drum to where the air exits the home.
They do make a brush designed to go into the area where the lint trap is and be long enough to come out the rear of the unit---A lot of places will come out and professionally clean from trap to vent outlet
A blockage can be dangerous as hundreds of fires happen each year from the lint catching fire in the dryer.
The tube to the outside may seem clear but if blockage anywhere from lint trap to it, that will cause this problem and present a possible fire hazard.
Its not unlike having your vac not pick things up very well...except there is rarely a fire with that.
SOURCE: Dryer runs but doesn't heat up when sttings call for heat.
You may need to do some troubleshooting. This can be done with the machine unplugged - you may have to activate the start switch, belt switch (if it has one) and the motor centrifugal switch manually.
Tip for troubleshooting 220v systems - clip one lead of a ohm meter to either L1 or L2 on the terminal block. It doesn't matter which one. According to the tech sheet (under console) follow the path for current from your clipped terminal, through the heating element, to the opposite terminal. All the readings should be less than 100 ohms, until you reach the failed part. Confirm failure by disconnecting a lead from the suspected part, and test only that part.
Live troubleshooting is sometimes slightly easier, but much more dangerous than the procedure described above. - It is definitely not recommended for beginners, or for professionals, if it can be avoided.
SOURCE: Kenmore Elite dryer heats but does not dry
Make sure that your vent tube is not kinked or crushed behind the dryer and it all this is ok then you need to change your cycling thermostat. is it gas or electric
SOURCE: Kenmore Elite He4 Dryer Model Number 110.85872400
Before assuming you have a bad heating element, read through the following link:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Most dryer heat related problems are attributed to poor ventilation which, in turn, causes the dryer to overheat to the point of failure. More commonly the Thermal Cut-Out (TCO) fails. The component acts as a fuse and must be replaced if bad. In addition, if the TCO is determined to be defective, it is recommended that you replace the Hi-Limit Thermostat at the same time. Both these components work in conjunction with the heating element and are mounted on the heater box. The TCO is located on the end opposite the heating element terminals. The Hi-Limit Thermostat is located adjacent to the heating element leads. These two components are often sold as a kit. If you fail to replace both of them you can experience premature failure of the component you do replace.
Pay particular attention to the section that discusses proper dryer ventilation. If you haven't checked or cleaned the exhaust ducting any time recently, now might be a good time to do so . A dryer left in a clogged or poorly ventilated condition will cause repeated failures in the heating circuit. Not to mention this creates a fire hazard.
If you read through the link and determine that you have a bad heating element, follow these steps to remove:
1. Unplug the dryer and remove the lower panel under the door.
2. Remove the lint screen from the dryer door.
3. Remove the blower fan housing vent cover.
4. Disconnect and label the component wiring on the heater box.
5. Loosen the mounting screw on the heater box front support.
6. The entire heater box, with element inside, should slide out of the dryer.
7. There should be a couple of mounting screws on the component side of the heater box that you need to remove and the entire element slides out.
If you still have questions, please let me know. I hope this helps you.
SOURCE: Our Kenmore 80 series gas dryer won't dry clothes.
Have you checked the entire run of the exhaust vent ducting? Cleaning the lint trap is not nearly enough to keep a dryer running efficiently.
A simple test you can try is to remove the exhaust vent hose from the back of the dryer and attempt to dry a load as you normally would. With the hose removed and the dryer running, the air leaving the exhaust of the dryer should be forceful and warm (about 140 degrees). If the air flow is weak or non-existent, you have a clog INTERNAL to the dryer. You will have to inspect the air blower fan housing and ducting inside the dryer to ensure the blower fan is not obstructed in any way. If the air flow is normal and the clothes dry like they should, you have a clog somewhere in the DUCTING from the point where it leaves the dryer to where it exits your home. You will need to inspect the exhaust ventilation for any clogs or kinks.
If you can see the heating element glowing, you probably don't have a problem with the heating circuitry. If you haven't checked the dryer ventilation recently, now might be a good time to do so. Leaving a dryer in a clogged, or poorly ventilated condition can cause the dryer heating circuits to over heat to the point of failure. In addition, this can also create a fire hazard.
If you have any questions, please let me know. I hope this helps you.
