Tighned the valves and now mower wont start
Steven, I think you have diagnosed your own problem. Check the specs you used to set the valve clearance. If you don't have any specs, set them both to .020" and it should run fine. Be sure that you set both valves just about 15-30 degrees before TDC on the compression cycle. (both valves closed)
junkl
SOURCE: murray riding lawn mower
with switch off try crossing out the solenoid. take an old screwdriver and place it on the two metal contacts jetting out from the solenoid usually by the battery or close to the ignition. if strarter engages when this is donr replace solenoid. if not replace starter. hope this helps.
SOURCE: Murray riding mower Mod. #30575x8a will not start.
Hello:
You can View a Schematic at the Following Site Addy. Select the OEM Briggs and Stratton (Murray Power).
Hope this Helps.
Good Luck
Respectfully
John
SOURCE: Murray Riding Mower will not move forward or back
my murray Riding Mower will not move forward or backward
SOURCE: murray 42'' riding lawnmower owners manual
www.murray.com
Locate the tag with your model and serial number on the tractor. Be sure you get the number EXACT or it won't work.
Go to Murray's website and download it. They usually have parts listings at the back of the Owner's Manual
