I double check the yellow red and black wires i also made sure i have the antenna pluged in what is wrong. why won't it power on?
You may not have connected the hot lead of the player to the correct 12 volt accesory source. If you connected to the lighter plug, the ignition key needs to be turned to "run" for most of those to work these days.
If you tapped the wires for the door switch for couresy lights, you need to pick a different ground wire connection and power feed. the door switch is usually a grounding switch for the courtesy lights which have no ground until that switch closes contact with an opening. door. The power you could draw from that circuit is minimal because the courtesy lights are in series with that player - if connected in that manner.
SOURCE: on my peavey pro 15
black and red will goto 1 speaker. and blue/yellow to the other. typically red and yellow are + and black and blue are -. the crossover board might tell you which is which where they solder to it. but i'm pretty sure the black/red goto woofer. try hooking up both to woofer and listen to it. 1 way is going to sound horribly wrong lol. that will mean you hooked up the tweeter leads to the woofer. but DO NOT HOOK UP WOOFER LEADS TO TWEETER. thats why i say to do it on woofer.
I have my radio install after a few mounts the screen light went off everything works perfect but the lights from the screen not working touch is perfect any suggestions?
