Dryers Logo
Posted on Jan 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool Duet GGW9200LL1 will not start
The control panel is working and beeps twice when the start button is pushed, but the dryer does not start. The problem occurred right after the dryer door was opened and there was an electric flash...
Let me know if you have an idea of what might be causing the problem.
  • lnick55 Feb 21, 2009
    My Whirlpool duet will not start. The start button just beeps. Used the diagnostic test of pushing any button for 3 seconds and release for 3 seconds 3 times. This showed F-01.We replaced the control panel with no change in the dryer.
    We tried the suggestion to emo's problem and the dryer door does not beep when we open the door and 09 is on the display. Help?
Anonymous
Level 3:
President:
  • Master 878 Answers
  • Posted on Jan 14, 2009
Anonymous
Master
Level 3:
President:
Answers
878
Questions
Helped
1202193
Points
3312
The electric flash does not sound cool, It sounds like you have a door switch problem. Check to see if the door switch button is in tact. If it is , you may have to go after the door switch itself. Try this, press more time, less time, more time, less time buttons in that order, the whole panel should light up, open the dryer door, you should hear 1 beep and OE displayed, If you have this the door switch is ok, Catriver
Whirlpool duet dreyer control lock On --can't program dreyer
try unplugging for a couple of minutes and it should reset to factory settings.
2helpful
My Duet Dryer starts runs a minute or two then beeps two or three times and stops. The display lights flash, if I push start it starts again but then stops again after a minute or two. I've gone t
I would first unplug the unit and remove the top cover. There are 3 screws towards the back of it. Push the cover back towards the wall and pull off. To the left you will see a control panel (usually black metal case), remove the 3 screws and flip over so you can see the control. Make sure there are no loose connections. I have ran into quite a few that had relay connection wires loose. If everything is ok. The next thing you would want to do is remove the front lower access panel (kick plat panel) and blower chamber. There is a thermal fuse and a thermistor located behind it. If you have a meter then take the proper continuity tests that are displayed on schematic. Both the thermal fuse and thermistor are fairly cheap. Click Here for a link to a thermal fuse on a Whirlpool Duet Dryerefd097de-8d08-43d9-8d3d-9f8b17924fb9.jpg
1helpful
Start button will not initiate on cycle. Get 3 beeps.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
2helpful
2answers
My whirlpool dryer just beeps when you try to start it. The panel is lit up the door is shut, push start and it just beeps...any idea what the problem is
To unlock the Control Locked feature:
Press and hold the End Of Cycle Signal button for 3 seconds to turn this feature off.
NOTE: When the dryer is running and Control Locked light is on, the dryer can be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If holding doesn't unlock the feature, it is likely a faulty interface. I am having the same problem with my Whirlpool dryer and it is the interface, but it seems that a lot of people are able to correct the issue just by pressing the End of Cycle button for 3 minutes.
Here is a link to parts, numbers, and prices from Sears:
http://www.searspartsdirec t.com/partsdirect/getSubComp.pd?modelNumber=GGW9250PW1&productCategoryId=0151200&brandId=1198&modelName=RESIDENTIAL-DRYER&diagramPageId=00001&componentDescription=TOP%20AND%20CONSOLE%20PARTS&documentId=W0508037&blt=06
My whirlpool duet dryer after selecting andpressint the start button , it beeps twice and the time flashes repeatedly and it the time thats flashing not a code it the whirlpool duet model ygew9250pw1...
Try unplugging it and see if it will reset the control panel.I would have to say if that don't work it's a problem electrical and unfortunately you will have to call a repair man.
Most of these machines are under waranty for two years.
1helpful
2answers
Beeps but doesn't start
Duet dry lights up, hit the start button and it just beeps and lights flash. but will not start.
Control locked on, can't release it
find button with lock emblem hold 3-5 secs if will not clear suspect either bad interface(buttons ) or bad connection or broken wire between front panel and interconnect on main control
245helpful
4answers
Whirlpool duet dryer won't start
whirlpool duet dryer has power but will not start--when I press start, it beeps once and the sensing light comes but the dryer doesn't start
3helpful
Dryer just says beep beep beep everytime I push start
sounds like you may have a bad door switch(mach thinks door is open when it is not).open door and look on front panel that door pushes into.you should find a small button covered in a grey rubber boot.push on it and listen for a click,if u dont hear a click the switch is bad.if u do hear a click it could still be bad or you can have a open thermal fuse
Top Dryers Experts
john h
