Everything is dead like its unplugged. What steps should I take to troubleshoot? I have some electronic bench tech training.
When you remove the front control panel you will see the two fuses in the next internal section. Below are instructions for removing control panel:
You
can do this without removing unit from wall. First unplug unit. Next
remove the two screws on the top of the unit closest to the front.
These screws simply keep the up facing vent in place. Next slide the
vent to the left (plastic latches on bottom hold in place) to allow vent
to be removed. You should now see a single screw above the control
panel. Remove it then open the microwave door. Gently slide the
control panel up which will disengage the plastic latches on the panel
sides. Suggest if you are going to remove the controller and replace
take a picture before removing it so you know exactly how to reconnect
all the wires.
You can find parts and a good diagram of the unit at the following sitehttp://www.searspartsdirect.com/partsdir...
Thank you both for the diagram site bob and Robert for instruction on removing front control panel. I do not see the 2 fuses only the one ceramic 250V 20A on the MO17 board. Where in the next compartment are they? I don't see them on the drawing either. Please help.
If you find the fuse blown or circuit breaker tripped, unplug everything from the circuit to which the microwave is connected (keep in mind that other outlets may be fed from the same circuit). Replace the fuse or reset the circuit breaker. If the same thing happens again, you have a problem with the outlet or other wiring on the same branch circuit. If plugging in the microwave causes the fuse to blow or circuit breaker to trip immediately, there is a short circuit in the power cord or elsewhere.
The microwave oven may be powered from a GFCI outlet or downstream of one and the GFCI may have tripped. (Removing a broken oven lamp has been known to happen.) The GFCI outlet may not be in an obvious location but first check the countertop outlets. The tripped GFCI could be in the garage or almost anywhere else! Pushing the RESET button may be all that's needed.
Next, try to set the clock. With some ovens the screen will be totally blank following a power outage - there may be nothing wrong with it. Furthermore, some ovens will not allow you perform any cooking related actions until the clock is set to a valid time.
Assuming these are not your problems, a fuse has probably blown although a dead controller is a possibility.
While you can do some repairs on your microwave, what you don't know can kill you... even on an unplugged microwave, so make sure you understand the dangers and how to reduce them before you try anything inside a microwave. If you want to do more yourself, go to the link at the top of this post.
