I dont know the model of this front loader washer, 7.5kilos capacity, white approximate 24" to 27"
Hello Ruby Torres - I understand that you will like instructions on how to operate the washer, however may I please have the model number so I can assist you better in pinpointing you the information. Generally speaking, the serial tag on a front load washer is usually located on the upper front, as you open the door.
SOURCE: Frigidare front load washer warranty
The usual factory warrenty periord on the Frigidare Affinity washer is 1 Year from date of purchase. You can find your Model number and serial number of your washer on the inside of the door. It is on a white label towards the bottom of the dorr.
SOURCE: small rug washing in front end loader washer
its problably not able to balenbace the load of rugs, if the machine cant balance itwont go to high speed spin. in actuallity your probalby better off bringing the rugs to the laundry mats, especially if the are rubber backed, the rubber backing will come off clogging your pump assy, then your looking at replacing hte pump for a few hundred dollars, for a clean set of $30 bath rugs.
SOURCE: Front loader will not spin
The problem is the door latch assembly. You can get it at your local parts supplier or oder it through repairclinic.com. Should cost $50-$55. My hubby is replacing mine now. Not an easy part to replace, but by all information I have gathered from the manufacturer and the parts department, this is a common problem and most likely the cause of the machine not spinning. It runs through all the rest of the cycles, but will not spin, even on spin only cycle. The good news... if you replace the door latch assembly once, the replacement part is much stronger than the original and shouldn't have to be replaced again.
SOURCE: I purchased the Frigidaire stackable
Your power supply has failed, need part # 134409904, check ebay, about $70
this board is in a white plastic box with wires running to the motor, access from the back of the machine, maybe say magnetek on it 4246-99-1
SOURCE: REPLACE BELT
Hi there ,
how do I get the belt around the drum ? do I have to take the whole back panel off the dryer ?
Don
