Garmin nuvi 255W GPS Receiver Logo
Posted on May 19, 2017
GLASS ON GARMIN BROKE
My girlfriend had a slip and fall accident with my gps in her purse and she landed on it and the screen cracked. the gps still turns on but none of the buttons work so i don't know what to do with it. i want to replace the glass. i have no warranty on it because it was a gift from best buy for participating in a survey. so could i in essance take it apart and replace the glass myself? or is it special space glass that can only come from the moon or something? sorry for the sarcasm i just am a little annoyed.
5 Related Answers
Anonymous
  • 6 Answers
  • Posted on Jan 30, 2008
SOURCE: Broken screen
if you post your e-mail add we can take this further as I may have a lcd screen that you can have for £20 + p&p
regards
TO Lady
  • 638 Answers
  • Posted on Apr 01, 2008
SOURCE: Cracked glass
If you're handy with small tools, you can make a new screen using Lexan, a Dremel tool to shape it, and then glue it into place. You'll have to dismantle the unit first to get the broken screen out.
Either that, or send it in to Garmin for replacement.
Anonymous
  • Posted on May 18, 2008
SOURCE: broken garmin screen
Like original poster, I've got a dent on my Garmin C320 screen - could see everything, but touch feature stopped working.
Just finished swapping the screen with the one from my old Dell Axim X3 PDA. Now GPS works again! It seems that older units were using industry-standard LCD that could be easily replaced. Not sure about newer Nuvi systems...
Anonymous
  • 426 Answers
  • Posted on May 28, 2008
SOURCE: replace glass screen on the 60 csx garmin
yeah sure with some handy work and a llittle patience you shouldnt have a problem just remove all the screws, be careful not to tear any wires remove the internal componets from your face plate take a small prying tool and remove the glass , just a few dabs of superglue and your back in business! if you want a shatter proof you can alsi use plexi glass.... and if your really adventerous you could remove the standard led's and put custom colors in .... but beware soldering on a board can be dangerous
sharcnet
SHARCNET-USA
  • 2130 Answers
  • Posted on Feb 17, 2010
SOURCE: i cracked the glass screen on my garmin nuvi 660,
Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
1helpful
The touch screen on our Garwin Nuvi 360 do not function.
Unfortunatly there is a fine wire Grid below the surface of the glass, the grid detects where you are touching on the screen, with the glass being broken, the grid is broken, which will cause dead spots or regions on the touch screen. You will have to replace the Touch screen or the unit which ever is most cost effective.
Hope this is of some help.
Ed
1helpful
1helpful
The glass is broke, can it be fix?
You actually broke part of the LCD Screen, you can replace the screen (or pay someone to do it) I would look around on eBay and see if anyone has a good screen for cheap.
Good Luck!
Dec 05, 2008 • Garmin GPS
2helpful
3answers
Garmin GPSmap 60CSX Glass Screen broken
There are third party Garmin repair services that will fix it for cheap. Also, I found an DYI GPS repair guide,so you can do it yourself too, not that difficult, the part is available on Ebay.
Oct 15, 2008 • Garmin GPS
I have a Garmin Nuvi 660 and the suction cup fell off the inside of the windshield and broke the screen on the GPS. I believe it is only the touch screen portion because the picture looks and acts fine. ...
If the unit is under warranty, then send it back to the manufacturer. I had one customer that had the same thing happen and the manufacture offered to replace her unit free of charge.
If the unit is out of warranty, the manufacturer will not sell you a replacement screen. You can find them on eBay, but unless you know how to take the Nuvi apart, you face damaging the unit further.
If the touch screen is bad, the Nuvi will not recognize any presses on the screen. Having worked on many of these units, there is really nothing to go bad on a touch screen unless its physically damaged or has become disconnected from being dropped. If it appears that the glass is cracked, then it is the LCD display that is bad. The touch screen is a clear film layer that lays over the LCD display.
I would strongly suggest that you purchase a Garmin friction mount and no longer use the window mount. With a friction mount, your Nuvi will not fall and the friction mount is legal in all 50 states, whereas a window mount may not be.
- Jim
Sep 29, 2008 • Garmin GPS
3answers
Garmin 660 broken screen
Its the LCD glass which has gone bad you cannot change it yourself,
1helpful
Garmin nuvi screen cracked
If they don't give you a new one under warranty, are third party Garmin repair services that will fix it for cheap. Also, I found an DYI GPS repair guide,so you can do it yourself too, not that difficult.
Jul 05, 2008 • GPS
Cracked screen on Garmin street pilot 330
Given the cost of buying a new LCD with touchscreen is about $130 USD + shipping. Your best solution is to sell the existing unit and buy a new Nuvi or recondition C330.
Garmin will repair the unit for $150 and provide the lastest update and map.
2answers
Cracked glass
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
