Have not installed yet, will it work on windows 8
SOURCE: uninstall PrintMaster Platinum 15 but have to reinstall access de
Make sure you can see all the files. (My computer --> Tools --> Folder Options ---> View (tab) --> <Select 'Show hidden files ...' option.
Find the folder you have indicated.
C:\DOCUME~1\Jan\LOCALS~1\Temp\{A35C2323-3CEA-405C-9569-EF5DDE930B2F}
Delete that flder.
Restart the computer and reinstall the software.
SOURCE: i have vista, tried to
Here is a link to their website which describes how to manually remove the software from the hard drive. Let me know if it doesn't work and we can try some other options.
http://www.broderbund.com/c-26-support.aspx
SOURCE: Trying to install Printmaster 15 for Windows 7.
Apparently no, it does support only Windows 98 / NT 4 / Me / XP. However, here is a thing you can try if a program cannot be run under Windows 7 because of compatibility issues, which is the case with Print Master Platinum 15. You right click on the executable file that will install the application and click Properties. Select Compatibility tab and check Windows XP SP3. If it installs do the same for the EXE file that will run the application. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
