SOURCE: LG Refrigerator - I need to remove the ice disp.
The dispenser cover snaps off. Look at the bottom corners of the dispenser faceplate and you may see small slots to put a small flat bladed screwdriver inside to help pry the faceplate off. This faceplate snaps on very tightly so it may seem like there are screws holding it in place, but it only snaps in.
Once you have the faceplate off the rest will be easy as you can see what you are doing and what you have to remove.
Note, if you are replacing the funnel you need to know that this part has been updated as of OCT 2005 (stronger clips to hold it in place) and it will not snap into the older funnel frame (the part it attaches to).
If the serial number for your model starts with 510KR or lower, then you will also need the updated funnel frame part number 3210JA0006S.
Hope this helps, please rate my solution.
SOURCE: My funnel broke too! What's LG's number?
Contact Us
For Audio/Video/TV, Computer Products, Home Appliances
U.S.A. Corporate Headquarters
1000 Sylvan Avenue
Englewood Cliffs, NJ 07632
Toll Free: (800) 243-0000
http://us.lgservice.com/index_b2c.jsp
SOURCE: LG LRSC26925TT ice dispensing funnel broken
Yes. But LG came out with a new frame for the funnel. So you have to order the funnel and the frame which is installed through your front control panel. Good Luck I just did it.
SOURCE: The funnel on the ice/water dispenser just broke
Yes, this is true but it is not a difficult job. All you need is a phillips screwdriver and and a flat blade screwdriver.
I'll walk you through the steps:
1. First you have to disconnect the button assembly. Pull it down until it stops, then pull it forward.
2. Next, remove the display assembly. To remove it you first must create a gap with the flat blade screwdriver between the funnel and the display frame and pull the frame forward. The cover dispenser is held on by a hook. Disconnect the display assembly by applying pressure to the upper part of the cover dispenser with your fingers and pushing the display assembly from the housing.
3. After you disconnect the display assembly, use the phillips screwdriver to loosen the four screws and remove the funnel.
Assemble in reverse order.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
SOURCE: My LG model LRSC21935TT side-by-side refrigerator
The part you need is 3016JA2002B. Good luck
Testimonial: "Thanks so much! I ordered the part and it looks like a very easy and cheap fix. "
