Kingston 2GB Secure Digital Memory Card Logo
A
Anonymous Posted on Dec 15, 2012
2 GD MICRO SD-CO2G TAIWAN IS LOCKED
SOME ONE PUT A PASSWARD TO 2 GD MICRO SD-CO2G
1 Related Answer
Anonymous
  • Posted on Aug 28, 2010
SOURCE: how can i format my locked micro sd
my memory card wants password but i did not create password in my memory card.so my memory card is locked.how can i solve this problem?
How we can break micro sd card passward?
please solved my kingston micro sd 2 gb memory cards passwerds
2helpful
My nokia 3110c micro sd 2GB memory card has been locked and i have forgotten my passward
Go to a computer center which recharge and also load music for phones or go to a service center of nokia and give them,they can unlock the memory card.
My 2gb micro sd memory card as locked so iwant to passward
hello,
sad to hear that but i have a problem same as you before. i can't open and all my files is in there. all you need to is you go to the expert that doing repair of that staff like computer technician you have find in your place because they are only way to save your files. they have there computer to program about recovery.
Or another option
you might have a bad card.I got a good deal on 8gb micro sd card here http://www.ioffer.com/i/8GB-MICROSD-MICRO-SD-MICROSDHC-MEMORY-CARD-SD-ADAPTER-141239431
hope it can help...
5helpful
My memory card 2gb microsd code SD-CO2G its not open in mobile and PC please help me
when transferring the micro sd to the pc from your mobile do you have to use an adapter? there is a lock on the sd adapter that when pushed down it wont let you edit your anything on your card.
is this the issue you are experiencing?
Unlocking micro sd memory card
Hi..
please follow the instruction in this tip you can retrive the passward for your micro sd card
http://www.fixya.com/support/r5357099-retriving_memory_card_password
Thanx
LG Rumor won't turn on
I had this problem too. Do you have a micro sd disk installed? If so, remove the micro sd disk. When you restart it should start right up, and then you can put the micro sd disk back in and all should work normally. I know, it is a big pain in the rear. For some reason when it boots up, IF there is a micro sd disk in, it tries to boot from the sd disk, and can't get out of that cycle. I don't like little bugs like this and will wait and see if I buy a rumor 2 or not the next time I replace one of my other phones.
Sir, how remove 1gb micro sd memory card password pls help me ME HAVING SAME PROBLEM 6500 PASSWARD OF MEMORY CARD LOST.......
place the card into a different machine ie computer, and format the card. then put it back in your phone
I want passward for micro sd 512
try 0000 or 1234 or 4321 if that does not work then take it to a mobile center and have then reformat it for you or you can reformat it yourself
Top Kingston Electronics - Others Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
