LG 32LH30 32 in. LCD HDTV Logo
Santi Posted on Aug 30, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a LG 32LH30 TV. When I power on the TV I get a picture in the top half of the screen and vertical lines in the bottom half.
Also I get a thin white dashed line across the middle of the screen. After about 10 minutes I get full screen picture. However the top third of the screen is lighter than the bottom two thirds. I still have the thin white line across the middle of the screen. I am using HDMI cables to my cable box. I took the back cover off the TV and the capacitors and everything looks good.
richie46
Level 3:
Top Expert:
  • LG Master 12,962 Answers
  • Posted on Aug 31, 2017
richie46
LG Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2941715
Points
58151
T con board is responsible for the image you see on screen as well as any anomalies.
1 Related Answer
brian murry
  • 14 Answers
  • Posted on May 15, 2012
SOURCE: Top third is good picture, bottom 2/3 is pattern..
Try replacing the HDMI cable for a good quality cable and do not use any force when inserting it.
Panaton tv no picture totaly blank
Maybe Bad caps in power supply,Crack or splits on top of cap or leaking, Check value of caps in power supply.
LG 32LH30 LCD TV Problem
IMO Seriously for $119 it's not worth it.
However, it does sound like a capacitor problem
If you are "Serious" about fixing I'd find a TV repair Forum.
Else I'd go here and get a new one.
https://www.walmart.com/browse/electronics/32-inch-tvs/3944_1060825_2489948_7156390
Best Wishes.
I have a LG 32LH30 TV. When I power on the TV I get a picture in the top half of the screen and vertical lines in the bottom half. Also I get a thin white dashed line across the middle of the screen....
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
LG 32LH30 screen won't power up. Red light at bottom glows hi to low, but no picture. Unplugged and waited overnight, plugged in again, still no picture.
There is a way to tell if you have a bad board, or a bad panel.
1. Make the room dark and turn on the TV. Can you see it light up? If so, does it stay lit or turn right back off?
2. If the panel lights, but you have no picture, I would suspect the T-con. Some units now have the T-con incorporated with the main board, so you will need to check.
3. If you never get any light at all, then I would suspect the power supply.
4. If you only get light for a second or two, then you have a bad panel.
2helpful
There are vertical 1" to 2" black lines that come and go. They are on the top half of the screen only. Also, the TV takes 40 min of flashing before the picture comes on. Our TV is about 5 years old. ...
Yes,This tv have two problems.One is the power supply board have dead capacitors,need it to replaced,the other is the vertical lining board on the bottom near the speakers need all the old lining to resolders.The shop will cost u $ half to repair,it to buy a new tv.
2answers
Multi coloured vertical stripes on plasma screen
With half of the screen working, and with a Plasma tv. I will look at the driver board as being bad. Take the back cover off, the driver pcb will be at the top or bottom of the set. They are only about 2 inches tall and will cover most of the lenth of the set (2 boards that run end to end). The board that is on the side of the tv that is bad is the bad board. Replace that board or have a tech replace it.
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
2helpful
2answers
Can only see half the picture
Locate Vertical Output device--replace w/OEM equiv.or better.
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
