I have purchased a skywatcher 127 goto second hand and I want to know if the goto is alighning properley from living room as no clear skies
SOURCE: GoTo Problem
Be sure that the telescope is configured for EQ SOUTH mode to tell it is in the southern hemisphere. Once a star alignment is completed NEVER manually move the telescope. Use only the control panel to slew. Everytime the telescope is move by hand, the motors do not know it has been done, and assume it is still pointing at the old direction. Check the manual for setup.
Here: http://www.celestron.com/c3/images/files/downloads/NexStar_SLT_manual.pdf
SOURCE: I need a manual for a skywatcher 127 auto- tracker
You already have the manual. Take the scope back and get a replacement.
SOURCE: having a clear sky last night i took my new scope
Stars are ALWAYS pinpoints of light when the scope is focused no matter how much magnification is applied.
You are NOT focused properly -- when you are you cannot see the secondary mirror or the "spider" bracket that holds the mirror.
You will NEVER see a star as a disk, only as a pinpoint light. If you are seeing what looks like a donut with a dark center you are not focused.
Testimonial: "thanks for the info "
SOURCE: I have skywatcher 127 goto
Yes because you will not be able to CENTER (or see) the two alignment stars,
